Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 11-11-2011, 02:35   #1 (permalink)
Cheater Don't Deal With Him
Member: 1316155
Thanks Meter: 9
which field to study to know about how to unlock phones
which field would i need to study to get invovled in unlocking phones? the how to etc making equipment etc.
The Following User Says Thank You to attsupplier For This Useful Post:
Old 11-11-2011, 02:54   #2 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,515
Friend! Buy Used Phones (Lockeds) Buy one or two Boxs and try Unlock
Flash-Change IMEI Etc.Is the best you can Make.When you have any
question put here. Any User Tell you how to Solve or make Etc.........
Regards
Haicha
The Following User Says Thank You to Haicha For This Useful Post:
Old 11-11-2011, 10:13   #3 (permalink)
dawood1208's Avatar
Member: 1093004
Thanks Meter: 4,382
Regards
Haicha
yes
but his question is different
Old 11-11-2011, 10:29   #4 (permalink)
alexlaboratory's Avatar
Member: 771230
Thanks Meter: 773
electronics, you need to do electronics in the communication field.
or you can do as many cow boys do here just try to learn along and they dare to call themselves technicians
Old 11-11-2011, 15:50   #5 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
[/IMG]
http://my.jetscreenshot.com/7540/20111111-ldmr-91kb
Old 11-11-2011, 16:54   #6 (permalink)
Member: 1316155
Thanks Meter: 9
yes i dont think you understand i know how to use unlocking boxes.I need to know how to build unlocking boxes. which field.
Old 11-11-2011, 19:10   #7 (permalink)
sunshine4u's Avatar
Member: 1383464
Sonork: 100.1669490
Thanks Meter: 100
for this field you must have some knowledge about Telecommunication .it will help u
Old 11-12-2011, 07:02   #8 (permalink)
darmiles's Avatar
Member: 177036
Thanks Meter: 934
learn 1st how make a unlocking progy..
if you know the first step
now you know the 2nd step 3rd step 4th step
if you dont know the first step. much better stay away from this section.Gsm Programming & Reverse Engineering
to learn small progy junst visit this site here
Old 11-12-2011, 15:00   #9 (permalink)
Member: 18966
Thanks Meter: 59
i think not funny to put some link for sex when the other want to learn something serious bad post
Old 11-14-2011, 00:56   #10 (permalink)
jeanbrume's Avatar
Member: 273511
Thanks Meter: 84
hi
9 irrelevent posts !
its not so difficult to say :
learn asembling some language or find a kit with mcu microp or similar minium system play with it some time to have a minimum understanding
then search here for simens joker or other source .
tray analyse all begin with small progy .... & here you gooo.
have a nice day.
best regard.
Old 11-14-2011, 01:10   #11 (permalink)
naturalsurfer's Avatar
Member: 113587
Thanks Meter: 16
Regards
Haicha
Are you a terrorist or what
Old 11-28-2011, 02:44   #12 (permalink)
MA7MOD_GSM's Avatar
Member: 1298774
Sonork: 100.1584126
Thanks Meter: 94
1st learn assembly
2nd learn Reverse engineering
3rd unlock phones
Old 11-28-2011, 02:55   #13 (permalink)
MA7MOD_GSM's Avatar
Member: 1298774
Sonork: 100.1584126
Thanks Meter: 94
Software reverse engineering is the art and process of understanding the intricacies of your own and commercial software at a lower level than the compiler, a fuller definition can be found here. Many reversers focus initially on the various protection schemes used by software writers to disable or otherwise prohibit the full use of their software since this is a convenient (if somewhat legally dubious) starting point with a definite challenge and end point. I personally however have used the knowledge I have gained through 'reversing' to :
i). Produce my own custom tools for circumventing / identifying protections.
ii). Recover usable source code to lost projects.
iii). Identify and understand how specific functionality is implemented.
iv). Debug hard to find errors.
v). Perform analysis of potentially hostile programs.
Sometimes reverse engineering can be the only way out of a development tight spot, however it is not a decision to be taken lightly.
Reverse Engineering is NOT cracking per se, although it is sometimes difficult to draw the fine line between them in the early stages. Most reversers deplore the tens of thousands of warez sites that waste good server space on the web (you probably know them already). If you are looking for easy cracks, key generators or just serial numbers lists then this site and reverse engineering will NOT be for you, even though this information can be obtained with fairly minimal effort I expect most warez aficionados will not find themselves reading this in the first place and certainly won't have a clue how to code, assemble and link a key generator, let alone spend hours upon end studying assembly routines.
By learning to reverse engineer yourself, you are gaining a set of valuable and marketable skills (malware analysis, intellectual property rights management and anti-virus / vulnerability research are booming industries), thus distinguishing yourself from the many losers who would rather waste their time searching through pages of bloated graphics and commercial **** sponsors than learning anything themselves. You'll also find (over a period of time) that your reversing efforts will become less focused on protection schemes and that your interest will move away from simple protection cracking, who knows, perhaps a job in hostile code analysis beckons.....
The Following 2 Users Say Thank You to MA7MOD_GSM For This Useful Post:
Old 11-29-2011, 02:10   #14 (permalink)
fypoi's Avatar
Member: 712832
Thanks Meter: 290
Please read your post and use your mind
free palestine
Old 12-01-2011, 08:40   #15 (permalink)
Member: 242211
Thanks Meter: 2
@ Darmiles
gusto siguro matuto ng tao !!!
wag masyadong mayabang boss....
galing ka din sa pagtatanong
nakita ko nga kung gaano ka kapursige sa sandwich>>>>>
give respect lol...
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.25766 seconds with 9 queries
