GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
09-05-2007, 19:52 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 418285 Status: Offline Thanks Meter: 0 | EDGE support by software? I heard that EDGE uses the same frequency as GPRS and GSM, is it possible to support EDGE in a GPRS phone by only upgrading the GSM Baseband firmware? And, as far as I know, GPRS uses the same frequency as GSM, is it possible to add GPRS support in a GSM only phone by upgrading the firmware? and why? Thanks |
09-19-2007, 11:21 | #2 (permalink) |
Crazy Poster Join Date: Jun 2005
Member: 152989 Status: Offline Thanks Meter: 11 | Typically not possible to upgrade from GSM/GPRS to EDGE with just simple firmware upgrade. They uses different modulation scheme, so the RF processing is different. Of course, unless the firmware of that part can be changed too (software defined radio?). |
Mtk cpu 6225 supported but flash id 9803 not supported by et-box:)- | sahil2000ind | ET-BoX | 2 | 05-25-2009 07:29 |
n85 8g is supported by client 1.04 or not supported | khalid0909 | JAF No Tp Unlocker by Cinek | 3 | 03-09-2009 23:56 |
v3 edge supported ? | Triminity | MSS Box II | 2 | 11-19-2008 16:01 |
V3 EDGE supported? | maikash2747 | Gsmfather The Wholesale Unlocking Database | 2 | 04-05-2008 20:07 |
>>> BB5 NOT SUPPORTED by Dejan Software 1.0b <<< | RNC_EBM | Nokia Base Band 5 ( BB-5 ) | 87 | 06-19-2007 16:53 |
