Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 03-10-2009, 12:36   #1 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
Who Can Give Us Some Info About Unlocking Methods In General ?!
I like to know some real info about how programmers deal with phones
like i see they can deal with bin files and read simlock code from it and so on
all i need is general info not to make unlocking program but just to add it to my personal info
so if anyone can explain here some general info that will be great
Good Flashing For All
The Following User Says Thank You to tsarkh For This Useful Post:
Old 03-10-2009, 13:52   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,086
few things which i know i can tell.
to unlock or communicate to phone
you need to know platform. that's the first thing.
you need to know how to deal with phone to repair something . that's the protocol of communication.
you need to know phone will work with calculated code or stored code at some where at phone. that's the algo third step.
you need to know that if phones commands which its accept crc / check sum which need to send with commands without it no reply you can get.
to unlock some phones its really easy in developing like reading code in stored area. and typing code at phone.
to unlock high security base phones like sagem which use calculation method. to unlock this type of secure platform need to calculate correct code which is not not easy at all.
to unlock some phone which have firmware read protected need to learn about there bootloader and unlocking at boot mode/flash mode.
but there are many things its depend.
The Following 2 Users Say Thank You to stanner_austin For This Useful Post:
Old 03-10-2009, 15:12   #3 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
Take some light reading:
http://www.eecs.umich.edu/~panalyzer/pdfs/ARM_doc.pdf
If you can read and understand that bad boy, your are on a first step of the ladder
The Following 3 Users Say Thank You to Dave.W For This Useful Post:
Old 03-10-2009, 15:18   #4 (permalink)
Member: 49752
Thanks Meter: 6,086
ho ho how can i forget.
copy
paste
usb and serial sniffer
this are tools many guys are using this days. inserted of doing there brain work.
hehehehe
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 03-10-2009, 23:09   #5 (permalink)
Registered User
Member: 924451
Thanks Meter: 3
The central of unlocking software developement is cracking (reverse engineering), you must to know how to develop first.
Old 03-11-2009, 11:53   #6 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
Indeed It is not Easy and that is something I know long time ago
but what is very interesting here is the the methods u explained here they are many and i am sure there are more and more as each single day we got new things in programming
so I like it so much to get this great info
thanks to all who posted here bro
Old 03-11-2009, 11:58   #7 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
It seems to me that the base start point to work with unlocking is to understand Assembly 100% then u can start look here and there for other things
as CPUs understand only this way ( Assembly ) so u have to give and take from it only by this way
or i am wrong in this?!?!
Old 03-11-2009, 13:07   #8 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
Probably the best way to start is to learn a programming language (higher level) from beginner level.
The reason is, if you analyze the phone ASeMbly code, find a solution- how can you implement this if you dont know how to write your program?
Also it will help you get into the "programming mind set", analytical and logical ways of thinking.
The Following 2 Users Say Thank You to Dave.W For This Useful Post:
Old 03-12-2009, 09:27   #9 (permalink)
doonyi's Avatar
Member: 821156
Thanks Meter: 42
where can one learn all this? i need to learn from a good programmer.
Old 03-12-2009, 10:07   #10 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
You can learn on your own, in your spare time. No need for a teacher.
Choose a language, something like VB .NET is a nice choice. The tools for making programs is free to download http://www.microsoft.com/Express/VB/ and you will be making nice looking applications in no time.
Then do a google search for forums (if you search google for "VB .NET forum" you will et many hits). Probably better is to buy a nice book and work through the chapters in your spare time.
Good luck!
The Following User Says Thank You to Dave.W For This Useful Post:
Mr Vahid shahabi give us a info about ult updates. islam01 ULT PRO 20 02-12-2010 22:09
Who can give the steps of like unlock to the ME240q justincel VygisToolbox 0 01-10-2008 04:47
Some info about putting DCT4 in test/local mode karwos GSM Programming & Reverse Engineering 7 09-07-2005 20:11
need some info about unlocking v66 with PST DomnulV Motorola P2k 0 03-05-2003 14:16
Need some info about crypting IMEI in BF3 Chuk BF, BG, TH, BHx Series 4 01-23-2003 10:11
Page generated in 0.16712 seconds with 9 queries
