[Guide] All the Acer Hard Reset procedures here |
[Guide] All the Acer Hard Reset procedures here Acer Z2 Liquid hard reset 1.Shutdown the phone 2.Power it on with Power + Vol- (will appear Acer logo and the phone will vibrate) 3.Once it vibrates, release Vol- and push Vol+. 4.The phone will vibrate again, release Vol + it will boot in recovery mode. 5.Use Vol- & Vol+ to highlight "Wipe data/factory reset" and use meniu to select. 6.Confirm "yes - delete all data". 7.Select "reboot" Here you have video tutorial: GSM-ABC |
Acer S500 hard reset Acer S500 hard reset 1.Power off the phone 2.Power on with Power + Vol down (Acer logo will appear and the phone will vibrate after 2sec.) 3.Once it vibrates, release Vol down and push Vol up 4.The phone will vibrate again, release Vol up, it will boot in recovery mode. 5.Use Vol down and Vol up to select "Wipe data/factory reset" and then use Power to select it. 6.Confirm "yes" 7.Once done, reboot the "cleaned" phone. Here you have vide tutorial: GSM-ABC |
acer E130 hard reset procedure If you want to reset your ACER beTouch E130 you need: 1.Switch off your phone 2.hold on 3 buttons-''volume up''+power+button"answering a call" 3. You will see a menu where select "data reset" or something like that(by the way,you can control a menu by a trackball) 4.Most likely, your phone should reboot itself, if not, pull out the battery PS If after hard reset,your phone displays black screen with some information about battery and smth else,try a next combination of buttons:turn off your phone >Press and hold the Volume up and Volume down buttons.>press and hold the Power until you feel your smartphone vibrate and/or you see the Acer logo screen. In that order! |
Acer Liquid s100 Hard Reset A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM. Caution if you perform a full reset, your Acer Liquid s100 returns to its default settings and looses all information that is not recorded in ROM. To perform a hard reset:
Acer Iconia A100 Tablet Hard Reset
Erasing cache... If the tablet shows a recovery error or any other unexpected condition, you may have made some mistake in the procedure. For example, if you hold the power button too long this can cause the device to go into a recovery mode. If you encounter this, don't worry. This is a common and correctable mistake. In such a case, just restart the procedure at Step 1. The procedure can take several practice runs to complete successfully. What follows is the step by step procedure. source: acertabletforum Br, azam |
Acer Liquid Z110 Warning! All data will be deleted! 1. Power off the phone 2. Press together volume up + power button until Acer logo will appear and the phone will vibrate after 2sec. 3. Once it vibrates, release the keys. 4. Use volume buttons to select "Clear flash" and then press the middle button to select it. 5. Wait until the phone restarts That's it! |
accer liquid z205 flash file need |
acer e39 IMEI invalid aFter write IMEI set on No servise Plz help anybody |
Acer Iconia A3-A20 Hard Reset & FRP Done!!! Hi guys, this method is if the volume buttons don't work, Done with NCK Box 1.- Select MT8127 in CPU 2.- Press in FRP-PATTERN-PRIVACY and Click in (META) Reset to Factory Default 3.- Connect the tablet off and wait until the job is done. Code: Action : Reset to factory default. https://i.ibb.co/chVrnHs/Acer-Iconia-A3-A20.jpg Enjoy and Regards!!! |
sir i need accer liquid z205 flash file thanks |
Thanks for the information. |
