10-01-2018, 05:06 | #1 (permalink) |
Junior Member Join Date: Jun 2018
Member: 2844140 Status: Offline Thanks Meter: 2 | What Is Magisk Manager and What Is It Used For Index
What Is Magisk Since most of Android features have been secured with Google’s SafetyNet system Magisk has become more popular than ever. With Magisk, users are able to have root and custom mods while the Google Pay services are being used. It works without system partition and modifying the boot partition. Therefore magisk is called as a “systemless” root method. It’s very easy to install and only require a few components. The Magisk Manager APK which can be used with Magisk is a very useful application to Root all the Android smart devices without any effect. Magisk System Requirments Before using the Magisk manager, the Magisk framework must be installed first.Magsik only requires a few requirements to be installed.
Note: In this guide, TWRP recovery has been used Download Magisk
Install Magisk Manager App After the Magisk framework is installed Magisk manager Apk is needed to manage it.Magisk Manager is the application that allows you to install modules
Uses
Actually, the Magisk manager APK is the important part of all the procedure. Because it lets the users get more benefits of the rooting method. Verifying Rooting To verify everything is fine,
Checking Google’s SafetyNet After doing everything it is essential to check if the device passes the Google’s SafetyNet check. Because SafetyNet blocks apps like Google Pay from working when the system is altered. In that case, Magisk works without the touching system. Let's check
Currently, the procedure going on like this. But the Google will occasionally restrict this by updates, but the Magisk developer will release fixes when that happens and be alert to catch the newly released Magisk updates. |
The Following User Says Thank You to Alex express For This Useful Post: |
