GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Android Development and Modding (https://forum.gsmhosting.com/vbb/f831/)
-   -   [Collection]Android Developers Tools !!!!! (https://forum.gsmhosting.com/vbb/f831/collection-android-developers-tools-1734449/)
Faheem Anjum 11-02-2013 14:09
http://www.oledecran.com/boot.png
Features:
You can send the bootanim in ADB if you enable debug or create a zip and flash it.
You can also resize the image or the display to correspond to your resolutions.
You can add your own animations, just create a directory in "bootanimations" program and put the bootanimation.zip file there.
Download====> bootanim_changer_install_exe_v2
Mirror====> bootanim_changer_install_exe_v2
RAR PASS:- gsmhosting
http://31.media.tumblr.com/tumblr_m4...1tnco1_500.gif
Faheem Anjum 11-02-2013 14:14
APK BATCH INSTALLER
http://dl.dropbox.com/u/508717/APKTool/1-Dir.jpg
Features:
Install Apk
Uninstall Apk
Backup & Restore Apk
APK Renamer
Install Apk To SD Storage
Wireless ADB Connections
App Data Backup & Restore
Backup & Restore SMS
Download ====> APK_Batch_Installer_Tool_v1.5b.exe
Faheem Anjum 11-02-2013 14:16
DROID MANAGER
http://cloud.addictivetips.com/wp-co...le-Manager.jpg
Features:
Navigate through phone files.
Copy from / to device.
Search for files on the device.
Change permissions.
Install user & system apps (to install system apps your phone mus be rooted)
Fix APK files title saved locally, view permissions and required SDK version.
Get build.prop file from device, change it and save back to device.
Create zip files, sign and push to device external storage.
Execute Fastboot commands, mostly used commands are built-in (e.g flash partition, erase partition)
Supports transferring files from / to device via wi-fi by using the Android App provided.
Extract custom Rom and edit build.prop, replace system / user apps, edit / add init.d scripts, add / remove kernel.
Change Boot Animation.
Change default Ring Tones.
Export and sign output zip file.
Create backup zip file that contains the system files to be effected by applying a theme or a mod. The zip file can be flashed via CWM.
Just tell the program which theme you want to apply and the files will be backed up from the phone directly.
Support for unpacking and repacking boot.img.
https://images.filehippo.net/img/ex/...d_manager_.png Droid Manager 6.3.1
Faheem Anjum 11-02-2013 14:19
ANDROID EVERYTHING TOOL
http://s21.postimg.org/tm1r11eaf/Untitled.png
Features:
Integrated Lcd Density Changer
Fixes Permissions
Show oem token code
Flash oem token
Flash recoveries
Flash recovery themes
Enable root permissions
Flash any .zip file
Flash a rom
Create a coloured logcat
Show CID
Write superCID
Backup device
Restore device
Relock bootloader
Reboot options
Advanced wipe Options
Pulls Files From Server
Manual Adb And Fastboot
Wipe Data
Wipe Cache
Wipe System
Wipe Dalvik Cache
Wipe Android Secure
Wipe Recovery
Wipe Boot img
Wipe Data,Cache
Wipe Data,Cache,System,Dalvik
Fix Low battery error
Automatically Kills adb Upon Completion Of Task
Unlock bootloader guide
Install custom recovery guide
Install recovery theme guide
Enable root permissions guide
Install roms or .zip files guide
Restore device to defaults guide
https://s8.postimg.org/uii4395j9/index.png
Download====> Ricky310711RomKitchen.zip
chuvanthuongvn 11-02-2013 14:28
its really nice! thanks,
i understand the function but sorry guys i really dont understand how to use this? how do you add the images my friend? have no options to copy it, event if i drag it.. can you give more explain ps...
Faheem Anjum 11-03-2013 06:59
i understand the fuction but sorry guys i really dont understand how to use this? how do you add the images my friend? have no options to copy it, event if i drag it.. can you give more explain ps...
hi you can use this manual :
Boot Animation Factory-Create,Preview and Manage Boot Animations
Boot Animation Factory is the best solution for creating, previewing and  managing Android boot animations. It's a product of many hours of work,  and has lived up to this date as the best of its class.
Key features:
  • Preview zipped boot animations (their actual format)
  • Preview boot animations from folder
  • Preview boot animation from phone (can save the boot animation to your computer)
  • Preview boot sound from phone
  • Create boot animations
  • Flip and rotate boot animations NEW!!
  • Export boot animations as GIF animations
  • Flash boot animations to phone
  • Flash boot sounds to phone
  • Explore boot animations
  • Favorites list of boot animations
  • Slick, easy-to-use user interface (can be themed)
  • Automatic update check option
  • Extended preview info (can be toggled in Settings)
  • No limitatins of any kind!
System requirements:
  • Windows XP SP3 or later (Windows 7 is recommended)
  • Microsoft.NET Framework 4 or later (Client Profile is also needed)
How to use Boot Animation Factory
How to create boot animations using Boot Animation Factory
  1. Go to Menu/Boot animation/New...
  2. Click 'Choose folder' and select the folder in which your 'part' folders are.
  3. Click 'Add loop' to add a loop. You can add as many loops as you want.
  4. When you finish adding loops, click 'Save boot animation' and save your boot animation somewhere on your computer.
How to preview boot animations using Boot Animation Factory
  1. Go to Menu/Boot animation/Preview...
  2. When the dialog appears, tick the first radio button (.zip file) and click OK.
  3. Click 'Choose boot animation' and choose the boot animation you want to preview.
  4. Optional: you have some options here, like playing a boot sound, setting custom speed, using custom size, or repeating/not repeating a boot animation. Set the properties as you wish.
  5. Click 'Preview boot animation' and enjoy the preview!
Previewing boot animations from folder
  2. Tick the second radio button (Folders) and click OK
  3. Click 'Choose folder' and choose the folder which contains your 'part' folders.
  4. Click 'Add loop' to add a loop. You can add as many loops as you want.
  5. Optional: you can play a boot sound, repeat/not repeat the animation or use custom sizes. Set those properties as you wish.
  6. When you are done adding loops, click 'Preview boot animation' and enjoy the preview!
Previewing boot animation from device
  2. Tick the third radio button (Phone) and click OK.
  3. In the first combo box, select (or type) where your boot animation is located on your device.
  4. In the second combo box, select (or type) the name of your boot animation
  5. If you want to preview the boot sound along with the animation, tick the 'Get boot sound' check box and set the destination and name of the boot sound in your device file system.
  6. Click 'Get animation' and wait for Boot Animation Factory to get the boot aniamtion and boot sound from your device. Optional: check whether you want Boot Animation Factory to wait for your device or not.
  7. Click 'Preview boot animation' and enjoy the preview!
How to flash boot animations to your phone using Boot Animation Factory
  1. Go to Menu/Boot animation/Flash to phone...
  2. Click 'Choose boot animation' and choose the boot animation you want to flash.
  3. In the first combo box, select (or type) where the boot animation should be flashed on your phone.
  4. In the second combo box, select (or type) the name of your boot animation.
  5. If you want to flash a boot sound, click 'Choose boot sound' and choose the boot sound you want to flash to your phone. Then select the destination and the name of your boot sound in your device file system.
  6. Check whether you want Boot Animation Factory to wait for device and reboot after flashing or not.
  7. Click 'Flash to phone' to flash your boot animation.
How to explore a boot animation using Boot Animation Factory
  1. Go to Menu/Boot animation/Explore...
  2. Choose your boot animation and explore your boot animation. Optional: you can export any frame and the desc.txt file from the animation by right-clicking on the file and then clicking 'Save desc.txt file/frame as...'.
(If you don't see the download button, here's the link: install_bootanimationfactory.msi
Faheem Anjum 11-03-2013 07:06
https://s8.postimg.org/p0kx1uq4l/htt...m_tml_CFSR.gif
TICKLE MY ANDROID
https://imageshack.com/a/img713/5061/vpoy.png
Features:
Tickle My Android is a command line tool for Windows that uses apktool to help you pull and decompile files from your Android phone or tablet.
But it can also:
change the battery icon,
change the WiFi icon,
change the signal icon,
change the emoticons,
change the notification toggles,
change the softkeys,
change the transparency of the statusbar (if the rom allows it),
zipalign apk files,
sign new apk files,
sign recompiled apk files in the same way as the original,
deodex apk and jar files,
resize and change boot animations,
change fonts,
create backup-generating flashable zip files
Download===> TickleMyAndroid - v15.1.0
Mirror Link===> TickleMyAndroid - v15.1.0
RABIULSK 11-30-2013 06:48
Originally Posted by Faheem Anjum (Post 9849494)
pls uplod others link........
xianryzen 11-30-2013 11:31
they are not in english language sad....
Akash78679 02-10-2014 07:11
regusting for application
Thanks for the information actually I am one of the Best astrologer in India and I want to build a android apps for my website. so can you build that? my website title is Best astrologer in India.
salisu87 02-20-2014 22:55
carry us along tnx guys weldone
ajit bs 04-03-2014 08:59
Uni-Android Tool V-3.01
Multi Operational Tool for Androids
http://oi61.tinypic.com/254v8yq.jpg
DOWNLOAD
multitechzone 04-04-2014 11:31
link got problem can't download
pradeep varma 04-11-2014 20:35
link not work deleted file
ajit bs 04-12-2014 05:55
here is the updated version
Uni-Android Tool V-4.0
More Powerful Scripts have been added and All bugs have been fixed
http://oi61.tinypic.com/o02zkg.jpg
4shared Link
Page generated in 0.25971 seconds with 6 queries
