11-08-2019, 23:39 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Tidikelt
Member: 834813 Status: Offline Thanks Meter: 125 | INZ APKTool 2.0 (Windows GUI APK Tool) . INZ APKTool 2.0 (Another APK GUI Tool) Easy and Small application (Windows GUI) based on recent tools, for Decompiling/Recompiling APK, DEX and JAR files. Generating keystore/Certificate, Aligning , Signing and Installs APKs Features : Decompile/Compile APK/DEX/JAR Files Zipalign, Sign and Install APK baksmali/smali tab (optional) Run time add/set "apktool.jar" update file (no need restart) Switch between apktool versions Framework installer / Framework tagging API Level selection dialog (for file being decoded/rebuilt) Extract APK, Zip back to APK 7z Compression level (0-9) Verify APK/JAR/ZIP files (if they are signed/modified) keystore gererate, list information, add/delete alias(es), password modify Switch between apksigner and Signapk Auto create/set directories Clear Directory/ies (Ctrl+D) Cancel Operation (Kills running process) Option to change default paths (next update) Spaces, Symboles and special characters in Filename supported Java heap. Default = 1024m ADB Push/Install APK .. (Use push for system APK) Read device information Full APK information (dump badging) backup Restore APKs (optional) Drop down history (main only) files Preview (*.xml, *.png , *.jpg .. ) resource files (*.xml strings , ..) Open/Edit with Notpad++ log files viewer (by date) Enable/Disable Log output Simple and Advance form (GUI) Skin change. Setting options are saved in inifile and will load on launch Other features will be added after "bug fix" (if u find, please let me know) DOWNLOAD link 1 : pwd =TDK11 link 2 : Without pass Requirements : Windows 7 or above Java SE/JDK NB : As known, there are different types of apktool.jar errors. if Error(s) occur(s) while decompiling or mostly while compiling, please, try first to switch to earlier version (in some case 2.3.4 works better) if error(s) still occurring, then check the log output (keywords) and do some research . Also look at apktool's github issues https://github.com/iBotPeaches/Apktool/issues by default, Manifest , *.smali and resource files(*.xml strings , .. ) are edited with Notepad++ if Notepad++ is not available in your programs folder, a portable npp will be used instead (it will temporarily be extracted to "Application data\local\temp\npp") This later will be deleted after application close. Regards. SAME as APKTool , APK EasyTool .. INZ APKTool by Tidikelt GSM, is neither intended for piracy and other illegal uses It could be used for localizing, adding some features or support for custom platforms, analyzing applications ..etc. Abdelbasset Madani (This GUI Tool creator) Special Thanks : Ibotpeaches and Contributors (apktool.jar) Google, Android NDK (adb, aapt, apksigner, zipalign) Bootstraponline (signapk) Igor Pavlov (7zip) JesusFreke (Baksmali/Smali) . |
The Following 12 Users Say Thank You to laptop.dz For This Useful Post: |
11-20-2019, 14:10 | #2 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Promoted For future development ,,,!!
__________________ To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! Best Wishes : [IMG]****************************/convkey/0fa4/qq0zcyol0fmauiu6g.jpg[/IMG] .:::Roy:::. |
The Following 4 Users Say Thank You to gsm mithun roy For This Useful Post: |
04-01-2020, 19:09 | #3 (permalink) |
Member: 834813 Status: Offline Thanks Meter: 125 | . 2.1.0 bug Fix Check for updates (on launch) Download and auto set apktool.jar update Added Manifest Application title edit (including the different languages translation) Resource files replace, save, delete.. Smali, XML String Edit , Cut , Copy, Paste, Delete .. Added Syntax Highlighter for XML format display time beside each process step (optional) Option to change/reset default Paths Portable java option (enabled) Java heap size increase Added apktool 4.2.1 Minor improvement Inz Apktool 2.1 Would be nice if u report any bug found (refers to the gui) (to fix next update) Regards. |
The Following 3 Users Say Thank You to laptop.dz For This Useful Post: |
12-25-2020, 23:59 | #5 (permalink) |
Member: 834813 Status: Offline Thanks Meter: 125 | . 2.2.0 Minor changes and bug fix + Apktool.jar 2.5.0 Inzapktool_2.2.rar (32-64 bits) link1 (Mediafire) link2 (androidfilehost) Inzapktool_2.2.rar (x64) link1 (Mediafire) link2 (androidfilehost) As mentioned in 2.5.0, 32 bit support is deprecated (apktool.jar will not support 32bit on v2.6.0) NB : Previous apktool.jar removed from versions list (you can also add from interface if needed) . Last edited by laptop.dz; 12-26-2020 at 00:05. |
01-06-2021, 23:06 | #6 (permalink) |
Member: 834813 Status: Offline Thanks Meter: 125 | 2.2.0 . File has been set to private because of a such bug I found if you've already downloaded 2.2,.. please, tick on check for updates (on launch) from UI option and restart Or Download from Here (Softpedia) Java is required before running any operation ! Even for downloading apktool*.jar update or selecting from local disk (since apktool jar version is auto checked first, compared with existing before being downloaded & added) Except for extracting/ zip back to apk adb operations.. check/read device information, install apk .. You can use a portable java in case u don't need to install (from Option/General, browse and select the bin folder) |
The Following User Says Thank You to laptop.dz For This Useful Post: |
01-20-2021, 19:40 | #7 (permalink) |
Member: 834813 Status: Offline Thanks Meter: 125 | 2.2.1 . Added decompiling with "Only disassemble the main dex classes . (classes[0-9]*.dex) in the root" (--only-main-classes) v2, v3, v4 signing scheme options (by default, apksigner.jar uses the values of min and max sdk version) "Treat warnings as errors" (apksigner.jar) is on by default (warnings will display in log output) Enable to Align and/or sign without decompile/recompile (moved from general to signing tab) Display full APK information (set to on by default) Added the Ability to capture device screenshot (auto save or prompt) Fix external adb.exe path containing spaces/characters.. by default captures are auto saved in screenshots subdirectory (runtime created) otherwize choose prompt (from UI settings) to be asked where to save DOWNLOAD |
04-29-2021, 02:45 | #8 (permalink) |
Member: 834813 Status: Offline Thanks Meter: 125 | 2.3.0 Application icon preview Application Title Edit (enabled) Added Toolbar (strings editor) Added Close button (Editor , App Title..) Tabs Added "Specify aapt location" (external) Added Application permission editor Added open with" dialogbox (optional) Added Keyboard shortcuts (menu item) Updated smali/baksmali to 2.5.2 SDK Tools updated Added check/download updates (runtime) Added "Set program as default for APK files" Bug fix and slight changes were made DOWNLOAD |
The Following 4 Users Say Thank You to laptop.dz For This Useful Post: |
08-19-2021, 23:04 | #9 (permalink) |
Junior Member Join Date: May 2021 Location: Pakistan
Member: 2988802 Status: Offline Thanks Meter: 2 | INZ APKTool 2.0 (Windows GUI APK Tool) Reload this Page Reply to Thread All you have to do is select your favorite hero skin and you’re all set to style on the battlefield. A skin injector tool is always recommended compared to traditional or modified APK files. What’s good about these tools is that they are not actually script-based files that will harm your smartphone. In fact, they are just a small chunk of code that is associated to perform the only specified requirement. Bellara Injector does is that it only conflicts with the game files that change the skin variation in real-time. There’s no haptic amount or coins or gems, there’s no custom overlay, everything is legal and within limits. However, it is always a good habit to follow precautionary measures. You can use a VPN tool when you’re injecting a custom file. Using this way, your identity will be anonymous and the game algorithm will not detect your account ID. Bellara Injector is free to download for Android users. You can download the latest version of the file from the provided link above. |
The Following User Says Thank You to NAVEED1234 For This Useful Post: |
05-16-2022, 14:42 | #10 (permalink) |
Member: 834813 Status: Offline Thanks Meter: 125 | INZ APKTool 2.3.0 / 2.4.0 Beta . What's new in INZ APKTool 2.4.0 Beta Added Open recent apk files Added Execute from menu (prompts for apk if not selected) Added Application Icon change Added Search bar for strings editor (F11 Shows/Hides Toolbar) Added Main Toolbar + Statusbar (Ctrl+F11 to Show/Hide Toolbar) Added Image Editor Automatic conversion between many graphic formats UI advance form improvements Skin change (mod) Image editor (F11 Shows/Hides Toolbar) Import (Open/Edit an image) Export (save as) Selection Tool (Rectanguler,Circular,Polygan, ...) Fill button (ColorFill, AlphaFill) BrushTool (Rectangular, Circular, Brush Size) Paint buttons (Line, Rectangular, RoundRect, Ellipse) Erase Tool Picker Tool (Alpha, Color, Alpha&Color) Rotation (Right, Left) Horizontal & Vertical Flip Adjust(Brightness, Contrast, Black&White) Negative, Gray scale Image Properties Download . |
06-17-2022, 09:26 | #11 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2519656 Status: Offline Thanks Meter: 0 | Promoted For future development ,,,!! __________________ To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! Best Wishes : |
