Alex express | 12-27-2018 07:27 | How To Flash Spreadtrum Android Devices Using Latest SPD Flash Tool
Are you owning smartphone which is powered by Spreadtrum chipsets? If so SPD flash tool will be very helpful when you are going to flash your smart device since it has exclusively been designed for Spreadtrum devices. Spreadtrum Inc. which is also known as Unisoc is a fabless semiconductor manufacturer in China who produce chipsets for mobile phones. Spreadtrum is the 17th-largest fabless semiconductor company in the world. PD Flash tool is officially developed by the company as Windows-based flashing software and it can be used to flash stock ROMs on any smartphone which uses Spreadtrum chipset. Features Of Latest SPD Flash Tool - Has the ability to Flash stock Rom and Firmware in .pac extension Firmware on any Android smartphone which has Spreadtrum chipsets
- Flashes stock ROM and Firmware in .P5C extension
- SPD flash tool format or hard Reset Spreadtrum chipset based Android smartphones
Currently, users are able to download SPD flash tool latest version 2018 as v21.0.0001 Requirements to Use SPD Flash Tool - A windows computer
- Relevant Spreadtrum USB Drivers for the smartphone
- Download Latest SPD Flash Tool
- Correct and compatible Spreadtrum stock firmware in PAC for the smartphone
- Recommended USB cable
Make sure to download correspondent firmware for your device otherwise it may cause to brick your device permanently How To Flash Stock Firmware On A Spreadtrum Device - Charge your smartphone fully
- Make a complete backup of your device
- Download Spreadtrum USB driver on your Windows computer and install them
- Download the Spreadtrum stock firmware and extract it properly
- Download and extract the SPD Flash tool
- Now, open the SPD Flash folder and execute the SPD application
- After execution, launch the application and connect it after switching off
- Click on the "Load Packet Button" which is located on the upper-left corner to load the firmware file
- When the firmware is loaded, click on the "Download" button which has been located on the upper-left corner with arrowhead
- If everything is OK and flashing process is done properly you will get a pass message on the third column of the chart on the SPD flash tool interface
- Now, disconnect your device from the computer and restart it, if the device is not rebooted automatically
Developer Credit
All the credit and compliments belong to Spreadtrum Communications.Inc for designing, developing and distributing Spreadtrum Flash Tool which is also known as SPD flash tool for free. If you are facing any problem when using SPD flash tool, try SPD research tool. |
