10-17-2012, 13:29 | #2 (permalink) |
Junior Member Join Date: May 2012
Member: 1755495 Status: Offline Thanks Meter: 1 | Initializing... DA_LIB_VER_5.0.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=18 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: SPICE_M5200_IND_V0.1.4 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x001D8000, size=0x00028000 All Done |
10-17-2012, 13:29 | #3 (permalink) |
Member: 1755495 Status: Offline Thanks Meter: 1 | spice-m5200 Initializing... DA_LIB_VER_5.0.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=18 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: SPICE_M5200_IND_V0.1.4 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x001D8000, size=0x00028000 All Done |
06-02-2013, 11:58 | #8 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Uttar Pradesh India
Member: 656277 Status: Offline Thanks Meter: 187 | |
The Following User Says Thank You to nitish1 For This Useful Post: |
10-25-2013, 14:12 | #11 (permalink) |
Major Poster Join Date: Nov 2006 Location: India Age: 36
Member: 392429 Status: Offline Thanks Meter: 5 | here is solution spice m5200 display hang Mobile Information: Baseband chip Version:MT6250 DSP Firmware Version:2000.00.00 DSP Patch Version:1.0 Software Version:SPICE_M5200_IND_V0.1.8 Hardware Version:BESTONE50M_11B_HW spice m5200 - Download - 4shared |
03-18-2015, 11:18 | #13 (permalink) |
No Life Poster Join Date: May 2012 Location: Sherghati (gaya) Bihar Age: 31
Member: 1761355 Status: Offline Sonork: 0818211 Thanks Meter: 105 | >>> Getting Mobile Connection Info... VCC Pin: GND Pin: Signal Pin:1, 2, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:1 RXD:2 >>> Please Hold the Power key... >>> Connecting Mobile... CPU_ID:MT625A Tip:This Mobile Support USB Flash... Hardware Version:CA01 Software Version:0001 >>> Downloading First Boot... Verifying First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00300000 -> 3M Flash ID:0x00EF004000160000 Flash Name:SF_W25Q32BV ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 >>> Erasing Flash Now.... >>> Writing Flash File... All Done... |
