Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
Blackberry CDMA Blackberry CDMA phones discussion, firmwares, tutorial, media, repairs. |
![]() | #1 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | Blackberry 8330 8703e 7103e 8130 Esn/Meid Repair THIS PROCESS STICTLY CONFINED TO EDUCATIONAL PURPOSES ONLY Blackberry 8330 8703e 7103e 8130 and many more Esn Repair process Only by CdmaWorkshop Lisenced Version Ref : CDMA Service Software / ESN Changer, SPC Unlocker... What you need: 1- Blackberry Device 2- Blackberry Desktop Manager 3- CDMA Workshop 3.x.x *** This is only tested on 3.x.x. and higher *** By older version only ESN can be repaired not pESNs 4- ESN/MEID That you want to right. * NOTE Make sure that the blackberry is on the lowest possible OS. If it is not you can get a "Read Error" in Workshop and you will not be able to Repair your device * STEPS Step 1: Open Blackberry Desktop Manage Step 2: Verify that your Blackberry is on the lowest possible OS. Step 3: Open CDMA Workshop. Step 4: Connect to the Blackberry Com Port that pertains to your device. Example > If you notice you will have two ports for Blackberry. They will be called "RIM Virtual Ports" Mine are Com 2 & 3. You will always want to choose the highest one. So in my case I will choose "3" Step 5: After you are connected click on "Read", then go to the "Security" tab and depending on your Blackberry send the "SPC" to your device. if spc is correct " SPC is correct phone is unlocked " will be prompted Here are the locations for the SPC code if your BB is not Verizon. BlackBerry 8130:1060:1070 BlackBerry 8330:1060:1070 BlackBerry 8830:1060:1070 BlackBerry 8703e:100D:1012 Step 6: Go to MEID and click on "Read" then go to the drop down menu and select "Universal, Ram Method" Then choose scan: Blackberry Storm: 0264 : 0269 Scan and save as scan1 or something similar. Then scan this location: 17B0 : 17FD Scan and save as scan2 or something similar. Once the scan is done open both of them and take "scan2" and copy all the addresses and paste it right under the last address under "scan1". VERY IMPORTANT *** DO NOT LEAVE A SPACE UNDER THE LAST ADDRESS *** Go ahead an put the cursor and the end of the last number and hit delete to delete any line that maybe under. To test just hit the down key. If it doesn't go down to the next line then you're good. * Once you have combined the scans save it. Either as scan1 or something else. Just remember what you named it and where it's at. Now if it is not a BB Storm 1 scan with this location: 1013 : 10D7 you don't need to combine since it's just one scan. Remember none of this will work unless you are running the lowest OS for that model. Go ahead and save the scan after it's done. Step 7: Now put the MEID Hex that you want in the box. Example A1000005478893 Meid Hexadecimal go back to "Universal, Ram Method' and this time choose "Load". Then find either, the combined scan BB Storm 1, or the just one scan, any other BB. Keep in mind that this does not work for the Storm 2, 9530, or the 9630. br, |
The Following 21 Users Say Thank You to ~AKSingh~ For This Useful Post: |
![]() | #2 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | ESN address 8130 ESN addresses: 1013:2F38 106C:CF60 1070:F7B8 1097: D47C 1098:25CD 10A5: D2F4 10A6:4AE0 10B4:20CE 10B5:44A1 MEID (pESN) addresses: 1015:8430 - pESN 109C:7804 - pESN 109C:C9E5 - pESN 10AA:864C - MEID 10B8:CC70 - MEID 10B8:B18B - pESN 10B8:B48D - pESN 10B9:F879 - MEID 10B9:EF8B - pESN 1071:5398 - MEID 1071:4D10 - pESN 109C:77B4 - pESN 109C:C995 - pESN 10AA:85FC - MEID 10B8:C514 - MEID 10B8:C525 - MEID 10B8:AE39 - pESN 10B8:B137 - pESN 10B9:F825 - MEID 10B8:CC70 - MEID 10B8:B18B - pESN 10B8:B48D - pESN 10B9:F879 - MEID 10B9:EF8B - pESN 1071:5398 - MEID 1071:4D10 - pESN 109C:7170 - pESN 109C:C351 - pESN 10AA:707C - MEID 10AA:E864 - pESN 10B8:A98C - MEID 10B8:A99D - MEID 10B8:9BB8 - pESN 10B9:E29D - MEID 1071:5398 - MEID 1071:4D10 - pESN 1075:7668 - pESN 109C:C9E5 - pESN 10B8:CC70 - MEID 10B8:B18B - pESN 10B8: D88D - pESN 10B9:F879 - MEID 109C:C9E5 - pESN 10B8:CC70 - MEID 10B8:B18B - pESN 10B8:B48D - pESN 10B9:F879 - MEID 10B9:EF8B - pESN 1071:5398 - MEID 1071:4D10 - pESN 1071:48A4 - pESN 1072:6D4C - pESN 1072:75BC - pESN 1075:7198 - pESN 109C:7170 - pESN 109C:C351 - pESN 10AA:E864 - pESN 10B8:A0CA - pESN 10B9:E29D - pESN 10B8:9BB8 - pESN 1071:5398 - MEID 1071:4D10 - pESN 1075:74AC - pESN 1075:7668 - pESN 109C:C9E5 - pESN 10B8:CE70 - MEID 10B8:B18B - pESN 10B8:BC8D - pESN 10B9:F879 - MEID br, |
The Following 9 Users Say Thank You to ~AKSingh~ For This Useful Post: |
![]() | #3 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | 8330m 8330m meid addresses MEID (pESN) addresses: 1015:8430 - pESN 1071:5398 - MEID 1071:4D10 - pESN 1071:4DE4 - pESN 1072:721C - pESN 1072:7A8C - pESN 1075:7668 - pESN 109C:7804 - pESN 109C:C9E5 - pESN 10AA:864C - MEID 10AA:FE40 - pESN 10B8:CE70 - MEID 10B8:B18A - pESN 10B8:B4A2 - pESN 10B9:F879 - MEID br, |
The Following 8 Users Say Thank You to ~AKSingh~ For This Useful Post: |
![]() | #4 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | 8703e 8703e ESn addresses ESN addresses: 1005:86F4 1005:B450 1005:C864 1010:5240 1010:5314 1012:0320 1012:0B78 1014:5004 1015:76B0 101F:F084 1028:226D 1015:75D4 1012:0B78 br, |
![]() | #5 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | Blackberry 9530 Esn repair - Downgrade firmware to 4.7.0.65 - Input the new MIED - Scan & save 0264:0269( text file 1 ) - Scan & save 17B0:17FD( text file 2 ) - Copy and paste text file 2 to text file 1 - Hit save and write. Note: use universal ram methol to scan and write. br, |
![]() | #6 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | 7103e Esn Repair BB 7103e RAM scan 1000-1027 and found ESN addresses: 1005:7934 100C:6CE8 100C:6DBC 100D:296C 100E:1DC8 100E:2620 1010:68A8 1011:8F54 101C:0928 1023:F04D br, |
![]() | #7 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | 8330 esn repair 8330 esn address from different Firmwares ESN addresses: 1015:8430 109C:7170 109C:C351 10AA:E864 10B8:9BB8 10B8:A0CA 10B9:E29D 1071:48A4 1074: D614 1075:7198 10B8:A0CA 10B9:E29D 1015:8100 1075:1E94 109C:1E6C 109C:704D 10AA:1D74 10AA:9560 10B8:4833 10B8:4D35 10B8:55FE 10B8:560F 10B9:8633 10B9:8F21 1015:8430 1071:48A4 1075:7198 109C:7170 109C:C351 10AA:7078 10AA:E864 10B8:9B72 10B9:E29D 1015:8430 1071:48A4 1075:6FE0 1075:719C 109C:7174 109C:C355 10AA:707C 10AA:E868 10B8:9BAE 10B9:E2A1 1015:8430 1071:4D10 1075:744C 1075:7608 109C:77B4 109C:C995 10AA:85F8 10AA:FDEC 10B8:B137 10B8:E639 10B9:F825 1015:8100 1075:1E94 109C:1E6C 109C:704D 10AA:1D74 10AA:9560 10B8:47F8 10B9:8F21 1015:8100 1070:F59C 1075:1E94 109C:1E6C 109C:704D 10AA:1D74 10AA:9560 10B8:482E 10B9:8F21 1015:8430 1071:48A4 1072:6D4C 1072:75BC 1075:7198 109C:7170 109C:C351 10AA:E864 10B8:A0CA 10B9:E29D 10B8:9BB8 1071:48A4 1015:8430 109C:7174 109C:C355 10AA:707C 10AA:E868 10B8:9BAE 10B8:A97E 10B8:A98F 10B9:E2A1 1015:8100 1075:1CD8 1075:1E94 109C:1E6C 109C:704D 10AA:1D74 10AA:9560 10B8:4335 10B8:4833 10B9:8F21 1015:8430 109C:7170 109C:C351 10AA:7078 10AA:E864 10B8:9B97 10B9:E29D 1071:48A4 1071:4978 br, AKSingh |
The Following 10 Users Say Thank You to ~AKSingh~ For This Useful Post: |
![]() | #8 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | BB OS 4.5...175 and above have memory access restrictions since phones like 8230, 8530 and 9630 came out with that OS version already there's no known way to enable mamory reading, and since there's no older versions hence no downgrade ![]() Beside these there are lot of issues in Blackberry Cdma like corrupted reg id leading to no spc access all can be resolved ![]() Some particular version of firmware not allows to access proper addresses need to be downgraded to only fixed versions ![]() ![]() bla bla ...... br, |
![]() | #9 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2002 Age: 42
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | Its only for those who have CDMA-WORKSHOP 3.X or higher any info about BB Specially cdma is really important post only relevant things NO THANKS POST NO OTHER SPAM or Links to other forums i will delete that otherwise i hope you people understand Good info and needs to be sticky |
The Following 9 Users Say Thank You to yousha For This Useful Post: |
![]() | #10 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2009
Member: 988879 Status: Offline Thanks Meter: 1,310 | Any info related to shareware software is useless to sticky. And this whole method can be done via qxdm or unicdma tool. Free of cost without buying any CDMA workshop. This look advertisement of CDMA workshop selling only. All know that akshing have no business now days accept CDMA workshop activation selling at 3x rate and saying bad words to other people at yahoo. Rolf |
The Following 5 Users Say Thank You to Advance cdma For This Useful Post: |
![]() | #11 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Apr 2005 Age: 42
Member: 137412 Status: Offline Thanks Meter: 5 | ![]() sir from where we will get the esn addresses for every phone thx ak singh doesnt have full knowledge abt cdma workshop because he just bought the cdmaworkshop start working sajinder from ludhiana have full knowledge abt the working of cdma softwares ak singh is also buying software from him he is a little kid against sajinder because thx.sajinder is using cdmaworkshop from three years and he also have dfs full version which the others doesnt have.i my knowledge he is the king of cdma softwares. |
![]() | #12 (permalink) | |
Member: 65063 Status: Offline Thanks Meter: 2,419 ![]() | Quote:
![]() ![]() ![]() is there anything left please write it here ![]() ......... | |
The Following User Says Thank You to ~AKSingh~ For This Useful Post: |
![]() | #14 (permalink) | ||
Crazy Poster ![]() ![]() ![]() Join Date: Mar 2006
Member: 239441 Status: Offline Thanks Meter: 19 | ![]() Quote:
NR | ||
The Following User Says Thank You to barodagsm.com For This Useful Post: |
![]() | #15 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 ![]() | Quote:
The Following User Says Thank You to luzer For This Useful Post: |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
I need the nsc/nsw ESN editor URGENTLY!Please help me! | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-19-2000 10:10 |
Nobody know the 6120 ESN promming? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-09-1999 04:35 |
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
ESN Change | OGOMEZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-21-1999 23:56 |
