Blackberry CDMA Blackberry CDMA phones discussion, firmwares, tutorial, media, repairs. |
12-04-2011, 16:44 | #166 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1698114 Status: Offline Thanks Meter: 0 | Blackberry 8130 cdma Flashing for Reliance india I bought one Alltell 8130 from ebay.I am trying to unlock it.i have found the spc which is "000000" . i wrote the Reliance PRL too. The problem now is,while its showing the network coverage,the data provider is still ALLTELL. Also when i try to activate it *228 it says my phone cant be activated.Through one of my friend in Reliance i have registered my esn ,but they say they cant find my phone..means their network is searching for my phone and its not detecting it. What could be the problem? i have QPST and QXDM installed. Please give me a step by step instruction about how to unlock a cdma phone and register it in native providers like reliance. Can i debrand the phone somehow? to completely erase any traces and settings of Alltel provider i mean. Also the phone is 3g enabled but it shows under the network icon as "1x" .does that mean i cant access 3g? is there anything else i should do to get 3g activated? i know there is a lot of questions But if smeone could help me through this,its much appreciated Thanks in advance. |
12-10-2011, 06:47 | #168 (permalink) |
Freak Poster Join Date: Jun 2010 Location: GSM Bunker
Member: 1330441 Status: Offline Thanks Meter: 95 | i have this problema with 8330 from Movilnet Venezuela. Blackberry OS 4.5.0.77 readed 1013:0000 to 10D7:0000 Scanning memory for ESN ad*******, in range of: 1013:0000 - 10D7:0000 ESN address has been found at: 1015:8430 ESN address has been found at: 1071:48A4 ESN address has been found at: 1075:6FDC ESN address has been found at: 1075:7198 ESN address has been found at: 109C:7170 ESN address has been found at: 109C:C351 ESN address has been found at: 10AA:7078 ESN address has been found at: 10AA:E864 ESN address has been found at: 10B8:9BAF ESN address has been found at: 10B8:A0B1 ESN address has been found at: 10B9:E29D capture. http://dl.dropbox.com/u/3930754/Foros/8330.jpg any solutions? Sorry, my english is bad. Last edited by compicarlos; 12-10-2011 at 06:55. |
12-17-2011, 01:28 | #169 (permalink) | |
Junior Member Join Date: Dec 2011
Member: 1701410 Status: Offline Thanks Meter: 3 | Quote:
12-19-2011, 05:20 | #170 (permalink) | |
Member: 1330441 Status: Offline Thanks Meter: 95 | Quote:
Sure? i going to try. write how do you do it. Last edited by compicarlos; 12-19-2011 at 05:28. | |
12-26-2011, 05:46 | #171 (permalink) |
Member: 1701410 Status: Offline Thanks Meter: 3 | fist make to factory os,wrte with jxdm,qxdm,anycdma free stuff or cdma-ware in default esn. i use this metode for write esn or meid to any bbcdma,no need scand add, work in 8330 bost mobile os 5 regards |
01-25-2012, 17:51 | #173 (permalink) |
Product Supporter Join Date: May 2004 Location: INDIA Age: 56
Member: 65063 Status: Offline Thanks Meter: 2,420 | to be noted ------ after scanning ram memory I repaired a blackberry 8130 Esn by following add resses ESN ad*******: 1012:F334 106C:9980 106C:9A54 106D:BE2C 106D:C69C 1070:C01C 1070:C1D8 1097:9E94 1097:EFE5 10A5:9D0C 10A6:14F8 10B3:C77F 10B5:0EB9 I changed ESN to 12345678 now again if I tried to change or repair ESN of same handset CW refused to change ESN and set re***** Now point to be noted is scanned RAM memory again and got new add resses with similarity Now I can repair ESN again ESN ad*******: 1000454 1012:F334 105B:F4D8 105C:0AC0 105C:20A8 106C:9980 1070:C01C 1070:C1D8 1097:9E94 1097:EFE5 10A5:9D0C 10A6:14F8 10B3:C790 10B5:0EB9 Once the ESN is altered for new repair you may have to scan again br, |
02-23-2012, 19:19 | #174 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,420 | 8130 esn address The best possible esn add. for Blackberry 8130 Code: ESN ad*******: 1000:D454 1012:F334 1013:2F38 105B:F4D8 105C:0AC0 105C:20A8 106C:9980 106C:9A54 106D:BE2C 106D:C69C 1070:C01C 1070:C1D8 1070:F7B4 1097:9E94 1097:D478 1097:EFE5 1098:25C9 10A5:9D0C 10A5:D2F0 |
02-23-2012, 19:34 | #175 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,420 | How to put AKey in Blackberry Code: ##msl code or ##XXXXXX where msl or x are 6 digit numeric screen will be prompted with numerous changeable data scroll down to akey remember : if you write akey via pc or cdmaworkshop ,one need to write Hex form of Akey not decimal Eg. 20 digit decimal Akey 12345678901234567890 16 digit Hex Akey AB54A98CEB1F0AD2 put 26 digit in AKey Column after calculating remaining 6 digit which is checkSum with repect to EsN or PEsn put SSdA and SSdB 0000000000000000 send correct spc to get access and write using correct method Note : incorrect method of writing AKey will lead to disconnection or call fading within 2 or more seconds, though Call can be made or received ! |
02-23-2012, 19:39 | #176 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,420 | Sprint Blackberry No *228 Code: Sprint Blackberry No *228 for Operator Provisioning Solution -Get the MEID Registered or Blank the Handset with proper registered DATA -Write PRL -Write AKey SSdA SSdB -Now Dail *22800000 or *228000000 for provisioning. |
03-14-2012, 22:43 | #177 (permalink) |
Member: 1706492 Status: Offline Thanks Meter: 0 | I have a Blackberry 8830 with an ESN. Is it possible to change the ESN with pESN which is derived from MEID using the registered version of CDMA workshop? Your help will be highly appreciated. |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
I need the nsc/nsw ESN editor URGENTLY!Please help me! | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-19-2000 10:10 |
Nobody know the 6120 ESN promming? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-09-1999 04:35 |
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
ESN Change | OGOMEZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-21-1999 23:56 |
