Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
04-06-2015, 06:47 | #1 (permalink) |
Insane Poster Join Date: Oct 2013
Member: 2056113 Status: Offline Thanks Meter: 20 | Is anyone here encounter this kind of problem logo only and keep restarting itself. Model: Sony Sation Ui Problem: Logo only and Keep Restarting itself. History: At first this phone was working fine with 2GB memory card.1 day my wife using this phone and it was freeze because it's not turning off even if i press the power button.So i decide to remove the battery and put it back then power on.that's the came up. Action Taken: 1. i try to remove the memory Failed still Logo only and Keep Restarting itself. 2. try to update using PC Companion Failed,because of restarting it cannot read the driver so it will also update. Please if anyone here encounter this kind of problem share and leave comments.. Thank You. |
04-07-2015, 06:13 | #4 (permalink) |
Member: 2056113 Status: Offline Thanks Meter: 20 | Thank you for your response sir @ moshman as of now that also my problem.cause i dont have box for this..but if i can find person that can fix this kind of problem...do you have any idea how much? |
04-07-2015, 07:32 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | it may different cause for restart 1 software 2 wifi damage 3 rf amplifier defective 4, defective lcd 5 defective mic 6.defective volume flex defective key pad strip if u are techincian then u can look into this above topic |
The Following User Says Thank You to akhil_bbsr For This Useful Post: |
04-07-2015, 10:05 | #7 (permalink) |
No Life Poster Join Date: Oct 2005 Location: England
Member: 193192 Status: Offline Thanks Meter: 327 | Flashing the phone should be cheap. Any repair shop should have the box they need to flash your phone. Start at flashing it, if that does not work then consider it a hardware problem - if you are not a professional then better to send to a repairer or scrap it. |
04-08-2015, 03:07 | #8 (permalink) | |
Member: 2056113 Status: Offline Thanks Meter: 20 | Quote:
as of now i have 2 jumper's on the unit.. | |
04-08-2015, 03:13 | #9 (permalink) | |
well as of now the last option i have is just to look for other defective board with RF and BB.. | |
04-08-2015, 18:03 | #10 (permalink) | |
Member: 193192 Status: Offline Thanks Meter: 327 | Quote:
You need to flash at bootloader level, only 'paid for' hardware will do this. | |
