Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
10-17-2003, 12:34 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Location: somewhere nice and warm Age: 61
Member: 38800 Status: Offline Thanks Meter: 1 | T610 reboot after 15 sec i have some problems with a T610 that reboots every 15 seconds. One of our customers have tried to unlock and upgrade the phone with Flashing_Gold 4.?? (sonyericssonserver.com) and after that, the phone reboots every 15 seconds. I have tried to flash the phone with DIV, but i always get an error 0101 Div says: Bypass boot authority and after 2% the error 0101 appears. Any Idea what i can do??? DIV works fine with all other phones :-) br Markus |
10-18-2003, 17:44 | #4 (permalink) |
No Life Poster Join Date: May 1999 Location: RU
Member: 83 Status: Offline Thanks Meter: 1 | 0101 after 2% can show what DIV dongle can't turn the phone ON via charging pin after first authorisation try. Check is the phone accepts charger. 0101 after 2% can't be software problem. |
10-18-2003, 18:36 | #5 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Slovakia Age: 46
Member: 5155 Status: Offline Thanks Meter: 7 | i has too two phones that stopped bypassing at 2%, both phones was flashed on DIV dongle, one was T68, second T610, i have maked it only with se-fighter and manual ignition. BR krtko |
10-20-2003, 08:30 | #6 (permalink) |
Member: 38800 Status: Offline Thanks Meter: 1 | @ SFlood The phone recognizes the charger. Any other Idea? Thankīs for your help anyway :-) @ krtko I hope i will get SE-fighter till wednesday (just ordered), what do you mean with manual ignition? Br Markus |
10-20-2003, 10:31 | #8 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | easy trick... there is easy trick to flash such phones with div. just do that steps: 1. open back case of phone so battery can be accessible 2. connect div cable to phone 3. start div, select flash files, press flash 4. now the trick - on t610 without back case we need to press with finger on battery to make contact. - when div progressbar shows 2% there is small delay before div shows error 0101 or 0102 and during that delay we must release pressure on battery so contact will lost and right after it press on battery again. voila ! progress bar shows 5% we must do such steps until div begin "load data to phone" . then do not release battery until flash is end. and all will be good - phone alive, unlocked and not rebooting. |
10-20-2003, 11:38 | #9 (permalink) |
Member: 83 Status: Offline Thanks Meter: 1 | Anyway, this problem related to auto turn-on malfunction. Another way to try: connect inverted ON signal (after first transistor) to phone ONSRQ/CTS pin 3. Its more reliable way to auto turn-on the phone. |
10-23-2003, 16:36 | #10 (permalink) |
Member: 38800 Status: Offline Thanks Meter: 1 | First of all, thanks a lot for reply. @ the_laser Thanks for your help. Trick might be easy, but i guess i am to stupid I managed it three times to 80%, but never to the end @ SFlood Thank you too I dont want to solder on the PCB as long as i havenīt try SE-Fighter. I hope i will get SE-Fighter at Saturday and i will give it a try. Anyway, can any of you two tell me what went wrong with the phone??? Is this a hardwareproblem or just something that went wrong with flashing gold? I dont think so, because i have sometimes problems with DIV and ARM flashing, DIV stops with an Error at 50%, but i allways can manage to reflash the phone, so any idea? Other question, how can i reflash a T610 Vodafone with the Vodafone ARM Section (R3C002_EU6-EU7) and where can i get a Vodafone GDFS file? Thanks Best regards Markus |
10-23-2003, 17:52 | #12 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | One warning: Although Fighter creates a 100% correct backup of full T61x/Z60x GDFS, you can't write it to the phone directly using the Flash AVR function. This is because the GDFS flash chip is not reachable from the original SE flashing applet. By flashing the file into the phone, you will get overwritten firmware. If anyone needs to convert such a backup into MDC form, we can do it. |
10-31-2003, 16:25 | #14 (permalink) |
Member: 38800 Status: Offline Thanks Meter: 1 | Hi, finally i got my SE-Fighter and managed to fix the phone. Thanks to all who tried to help. SE-Fighter is a nice piece of Software! Best regards Markus |
01-31-2004, 20:34 | #15 (permalink) |
Freak Poster Join Date: Feb 2002 Location: singapore Age: 46
Member: 9194 Status: Offline Thanks Meter: 3 | I had a problem with one pieces of T610 i tried with SEF cant entered boot ... try manual ignition also no success any helped?? I used 2.56b and the phone completely new set .. I just wanna unlocked it.. any help. . |
my X8 restarting after 15 sec. | raulioservice@y | Sagem Hardware Repair Area | 1 | 06-01-2008 16:53 |
N2626 or 1600 after 15 sec bluescreen | vipinverma | Nokia Hardware & Hardware Repair | 1 | 05-27-2008 14:51 |
3100 Power Off After 15 Sec. | erkan06us | Nokia Hardware & Hardware Repair | 15 | 07-09-2006 19:57 |
6680 reboots after few sec | telkomsa159802 | Nokia Base Band 5 ( BB-5 ) | 2 | 12-29-2005 20:23 |
T610 reboots every 15 seconds | excel service | Sony Ericsson Hardware Repair | 9 | 09-22-2005 19:28 |
