Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 11-28-2007, 09:57   #1 (permalink)
    Member: 470292
    Thanks Meter: 147
    K800i Unlock not done
    SERVER SUPPORT ENABLED.
    ALTERNATIVE SECURITY BYPASS ENABLED.
    ChipID:9900,EMP protocol:0301
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    OTP LOCKED:1 CID:51 PAF:1 IMEI:355*********7 CERT:N/A
    FLASH CID:52 COLOR:RED
    Model:K800i
    MAPP CXC article: R1JE001 prgCXC1250568_HUTCHISON_WI
    MAPP CXC version: R1JE001
    Language Package:HUTCH_1
    CDA article: CDA102511/69
    CDA version: R19A
    Default article: cxc1250490
    Default version: R1JE001
    Network LOCKED
    Operator: MULTIPLE
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed:13 secs.
    Speed:921600
    OTP LOCKED:1 CID:51 PAF:1 IMEI:35570401932227 CERT:N/A
    PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
    LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
    Flash ID check:897E
    Flash props sent ok
    CID52 BYPASS PROCEDURE STARTED
    Processing part1...
    Processing part2...
    Processing part3....
    OTP LOCKED:1 CID:51 PAF:1 IMEI:355*************227 CERT:N/A
    Flash ID check:897E
    Flash props sent ok
    REMOVE CABLE FROM PHONE
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    CID52 BYPASS PROCEDURE FINISHED
    Speed:921600
    Trying to launch embedded bootloader...
    embedded flashloader not responds !
    Elapsed:960 secs.
    Now Phone does not power on.
    Old 11-28-2007, 10:06   #2 (permalink)
    Member: 177408
    Thanks Meter: 20
    just flash the phone with it's original firmware..
    on settings..
    check unlock after flash\
    check use server
    check enable alternative
    use i.p adress 198
    Old 11-28-2007, 10:19   #3 (permalink)
    Member: 470292
    Thanks Meter: 147
    But how will flash it ufs interface gives the same problem. Usb cable is not connecting.
    Old 11-28-2007, 12:41   #4 (permalink)
    damabib's Avatar
    Member: 106026
    Sonork: 100.77890
    Thanks Meter: 127
    Use Bugs Fixed Version All Is Well Now..
    Logs Consumed unlock not done. Now need logs to unlock mishaelwillo Universalbox 1 09-04-2009 00:50
    Smasung C140 SP Unlock not done. amol_sm Infinity-Box 4 04-13-2008 08:47
    Alcatel E205 unlocking not done..? harim_1981 Multi-Box 6 03-24-2008 13:56
    My210x Unlock Not Done phoneteam SMTi 5 01-09-2008 08:34
    [K610i]Unlock not done Seifter KULANKENDI Server 2 01-05-2008 20:28
    Page generated in 0.13563 seconds with 9 queries
