Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
05-09-2008, 13:34 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | Z310 Unlock Successfully with Setool@914029 Successfully unlock my first Z310 with new update thanks to setool for great support i love with my setool Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 skipping empty loader... OTP LOCKED:1 CID:51 PAF:1 IMEI:354640******xx CERT:RED Model:Z310i Brand:T-Mobile DE MAPP CXC article: R1JC002 prgCXC1250594_GENERIC_AL MAPP CXC version: R1JC002 Language Package:T_MOB_INT_A CDA article: CDA102670/38 CDA version: R12A Default article: cxc1250595 Default version: R1JC002 PROVIDER: 000-00 Service provider LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 80 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:354640******xx CERT:RED LDR:070212 1651 GENCXC1720441_R2A019_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070503 1431 HANCXC1250610_R3A015_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM47 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK HOLD "C" BUTTON AND ATTACH AGAIN bypassing security... ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R1JC002_CXC1250594_GENERIC_AL Restore from:R1JC002_CXC1250594_GENERIC_AL full sig complete. USERCODE RESET TO "0000" Searching... Firmware lock check determined. Unlock DONE Elapsed: 131 secs. |
The Following User Says Thank You to Kanwalgee For This Useful Post: |
05-09-2008, 23:07 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 36
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | setting HI BRO WHAT IS THE SETTING FOR Z310 UNLOCKING PROSSEC TELL ME AND CLEARELY WRIGHT THE THE SETTING AND U USING B.R SHERRY MOBILES |
05-10-2008, 16:03 | #5 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 50
Member: 122044 Status: Offline Thanks Meter: 0 | hi where i can find the rest file for this model :I search in support but there is'nt any thing Quote:
