Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
11-26-2009, 02:54 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 452892 Status: Offline Thanks Meter: 104 | W580i Die afte flash many times! any solution? |
11-26-2009, 03:13 | #4 (permalink) |
Member: 452892 Status: Offline Thanks Meter: 104 | here is my log.. v0.915056/UNI CARD SERIAL: XXXXXX Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 8/22 CARD COUNTERS: FLASH 482, UNLOCK 74 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID:897E GOT SEED:2900D79F2380072C0030AD7A P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100502483 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100502483 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:897E writing "D:\Flash BOX\SETOOL 3\Setools\v0.915056\gdfs_in_ssw_format\db2020\W580 _GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "80347506" SIGNING... Elapsed: 43 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100502483 CERT:N/A FLASH CID:49 COLOR:BROWN PROCEDURE WAS STOPPED BY USER can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 8 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100502483 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:897E writing "D:\Flash BOX\SETOOL 3\Setools\v0.915056\eroms\db2020\DB2020EROM_CNV_RE D52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "28184373" SIGNING... Elapsed: 10 secs. |
11-26-2009, 03:39 | #5 (permalink) |
Freak Poster Join Date: Apr 2007 Location: nigeria
Member: 487753 Status: Offline Thanks Meter: 4 | Ho sorry bro,i dont know much about setool but i can tell you procedure that can fix your phone with cruiser.i think you made mistake to flash the phone with w850 file in the first case.but you can still fix the phone by 1.flash the phone with w580 flash file 2.download gdfs file for w580 from support and reconstruct the gdfs. you may need log for this. 3.your phone will be ok |
zv10 dead after flash bad boot any solution? | ionutz808 | QUALCOMM Models (3G) | 17 | 06-14-2007 16:44 |
9500 blinking after flash with fls4s,any solution? | Victor the | WD2 & APE (Symbian Phones) | 5 | 02-17-2006 14:56 |
Fizio 311 dead after flashing with Andro , any solution ? | kazak | Philips | 6 | 09-08-2003 12:33 |
