Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
09-27-2004, 23:40 | #6 (permalink) |
No Life Poster Join Date: Oct 2000 Location: Split / Zagreb, Croatia Age: 53
Member: 2236 Status: Offline Thanks Meter: 58 | I will try to cut z200_125718_r6c_con1.bis z200_125718_r6c_fix1.bis files from this BIN file that I have just read from a SIMPA Z200 prepaid package ... Hope I will not cut wrong... will test and inform you... Spalato |
09-28-2004, 00:45 | #8 (permalink) |
Member: 2236 Status: Offline Thanks Meter: 58 | Well, I definately did something wrong... I tried to convert 8192 KB of *.bin file to ARM with bin2arm.exe but I got 8193 KB *.arm file... little to big, I would say Where to cut correct to get the normal size of *arm file after conversion with bin2arm.exe ? Spalato |
09-28-2004, 08:36 | #9 (permalink) |
Freak Poster Join Date: Nov 2002 Location: EVO VIII FQ400 Age: 44
Member: 17806 Status: Offline Thanks Meter: 8 | Try this way : 1. Use Hex Workshop Hex Editor to open the file 2. Go to the END of this file, than use SEARCH function in Hex Workshp to find a Text String named "IDLE"! You have to search from the end of the file and search upward. In other words, you are looking for the first "IDLE" from the end upward. 3. When you find the "IDLE", delete all "FFFF" and the rest of file afterward. 4. You are expected to get a result like above! Save the file and use bin2arm convertor to convert it to modem flash files for DIV format. 5. Start Command Prompt and type "bin2arm YOURFILENAME" 6. When the conversion is completed, you will get a file named "YOURFILENAME.arm"! This is the modem flash files for DIV format. Or you can find more info here : http://forum.gsmhosting.com/vbb/showthread.php?t=161820 |
09-28-2004, 09:13 | #10 (permalink) |
Member: 2236 Status: Offline Thanks Meter: 58 | It didn't help... looks like that Twister reads it little different than SEtool because, I got 8192 KB readed with Twister and I did as you said, searched for IDLE but the first IDLE from the end is somewhere in the middle of the file and no FFFF's are afterwards so it probably should be cut in a different way... I'm just asking.. trying to learn... Spalato |
09-28-2004, 11:30 | #11 (permalink) |
Member: 17806 Status: Offline Thanks Meter: 8 | There is a .sbn to .bis convertor here http://forum.gsmhosting.com/vbb/show...1&postcount=30 , also look there what are instructions for .arm to .bih converting with same tool Another soolution is if Z200 is supported by SETOOL , you'll have to find out start address and length , if not we should ask "the_author" ( BR ) to implement it , or we can seat and wait until "smiling crocodiles from the small lake feed themselfs enough" hehehe |
09-29-2004, 00:06 | #12 (permalink) |
Member: 2236 Status: Offline Thanks Meter: 58 | Well, I did my best... spent hours on my laptop trying to get a ARM file for DIV from this BIN file that I have read with Twister... I also have read all stuff on this forum that is available and which speaks about this mather and still no correct converted file... If anyone has the will to shortly explain me how to make ARM from this Twister BIN, would be very thankfull... BIN file has 8192 KB... Spalato |
09-29-2004, 02:33 | #14 (permalink) |
Freak Poster Join Date: Aug 2004
Member: 77254 Status: Offline Thanks Meter: 9 | I've read that z200 is ARM based phone I don't think what sPoK explain regarding converting bin to ARM (which is for Flash Modem in AVR base phone) will work. But it's worth to try. |
09-29-2004, 09:06 | #15 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Novi Sad, Serbia Age: 44
Member: 17193 Status: Offline Thanks Meter: 16 | Spalato, thx for all the efforts... Could You maybe send that twister read file to [email protected] ? It should be about 3.5MB packed... |
Z200 r6c cfg1 | Plavush | DIV | 0 | 11-30-2005 10:12 |
z200 r6c con1 ??? | ProfiTel | UFS2 + UFS3-Tornadoflasher | 2 | 10-12-2004 00:42 |
Z200 R6C -just my experiance!! | hallo | Sony Ericsson | 2 | 09-24-2004 08:16 |
Z200 R6C can't be flashed with Fighter 3.13 | comunicatel | Cruiser Suite | 3 | 08-11-2004 18:12 |
Z200 R6c | hrich | Cruiser Suite | 0 | 07-08-2004 19:29 |
