Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
03-29-2010, 13:01 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: dhaka,bangladesh
Member: 649043 Status: Offline Thanks Meter: 18 | PLEASE HELP FOR U10i RUNNING v 1.01/UNI CARD SERIAL 00082103 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:F002,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0053 OTP LOCKED:1 CID:53 PAF:1 IMEI:35681503432161 CERT:RED LDR:2009-10-26 14:07 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A087 LDR:2009-10-26 14:08 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A087 Model (from GDFS):U10i MAPP CXC article: R7AA071 prg1226-0429_APAC_RA MAPP CXC version: R7AA071 Language Package: APAC-ANZ CDA article: 1227-2274 CDA version: R5A Default article: 1223-3057 Default version: R7AA071 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SECURITY UNITS BACKUP CREATED. Elapsed: 19 secs. SIGNED MODE (USING SERVER) CFG:100110000000 ChipID:F002,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0053 OTP LOCKED:1 CID:53 PAF:1 IMEI:35681503432161 CERT:RED LDR:2009-10-26 14:07 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A087 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2009-10-26 14:08 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A087 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA writing "F:\SE tool\setool\Flash file\U10i\R7AA071_APP_SW_1226_0429_APAC_RA_REDBROW NBLUE_CID53_52_49_DB3350.software" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:53 Will flash 946 blocks... ssw file accepted writing "F:\SE tool\setool\Flash file\U10i\R7AA071_FS_APAC_ANZ_RA_REDBROWNBLUE_CID5 3_52_49.software" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:53 Will flash 1906 blocks... ssw file accepted USERCODE RESET TO "0000" [startFS] can't get NET header Elapsed: 807 secs. |
03-29-2010, 14:13 | #2 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
common for all CID: 1. go to semc a2 tab, select proper model 2. add to firmware area correct MAIN, FS IMAGE parts of firmware. order not important. 3. select in misc. field needed CUSTPACK (.zip archive with customization files) 4. if you do not have CUSTPACK, you MUST check on settings "customize phone after flash" 5. set "signed mode" on settings tab. 6. set other settings according your needs. 7. back to semc a2 tab, press flash. | |
03-29-2010, 16:13 | #4 (permalink) | |
reflash phone with latest firmware version. try differnet firmwares. if still same,i hope Flash IC faulty.... | |
please please help for M200 terminal betry | chronic | Samsung Hardware Repair | 1 | 01-24-2010 19:56 |
please help for this flash for MYX6-2 | lahdache | SMTi | 2 | 11-22-2008 20:25 |
Please help for DEAD L6, need your help! | KUBAT1 | Motorola P2k | 5 | 03-30-2006 18:57 |
@hi lead please help for k750i unlock please | cellworld | Cruiser Suite | 2 | 07-18-2005 14:19 |
please help for the usb cable for V220 | HealMySoul | Motorola P2k | 1 | 04-15-2005 23:30 |
