Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
03-27-2006, 14:56 | #31 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Florida
Member: 250144 Status: Offline Thanks Meter: 1 | Thanks Kevin |
03-27-2006, 15:45 | #32 (permalink) |
Freak Poster Join Date: Dec 2003 Age: 45
Member: 45716 Status: Offline Thanks Meter: 38 | I Flashed A T630 That I Got Was Dead.everything On The Phone Is Working But When U Make A Call U Cannot End Or Press Any Of The Keys.what Could Be The Problem Thanx In Advance. |
03-27-2006, 17:13 | #34 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: 127.0.0.1 Age: 79
Member: 545165 Status: Offline Thanks Meter: 578 | Quote:
wbr | |
03-27-2006, 17:46 | #35 (permalink) |
Member: 248030 Status: Offline Thanks Meter: 29 | My Z800 died after flashing with TMS 2in cable and SETool.. I used these two files: Z800_R1AB014_FS.chp and Z800i_R1AB014-MAIN.chp... Here's the log from the flash: standalone version engaged. Card serial:00001283 Loaded 49 flash descriptors Open COM port OK ChipID:7100,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:36 Speed:921600 DB2000 only supports 460800,fallback. OTP status:0 locked:1 CID:36 PAF:1 IMEI:35599100038188 CERT:BROWN Loader:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok Switching to USB... Phone stays at current interface. Flashing MAIN firmware:E:\APPS\MOBIL\Firmware Flash\Z800\Z800i_R1AB014-MAIN.chp CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is:268 Will flash 268 blocks... SSW loading returns:0 Flashing FS image:E:\APPS\MOBIL\Firmware Flash\Z800\Z800_R1AB014_FS.chp CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is:97 Will flash 97 blocks... SSW loading returns:0 Don't forget check complete ! CID changed succefully. Open COM port OK OTP status:0 locked:1 CID:36 PAF:1 IMEI:35599100038188 CERT:BROWN CSloader version: 040616 1028 GOHCXC125904_SEMC_FILE_SYSTEM_LOADER_R2B loader startup: executed csloader refused to start fs services,error is:1 loader filesystem startup failed, that is fatal Elapsed:613 secs. Please help me get my phone back to life...I miss it badly... |
03-27-2006, 21:18 | #37 (permalink) |
Junior Member Join Date: Mar 2006
Member: 249432 Status: Offline Thanks Meter: 0 | hello now i have the original problem with my W550i i have that white screen! now... taking the battery will not work... leave him there will also not work i do not always get a white screen, sometimes i have the same screen like its off but in the power button there is a RED LIGHT FLASHING... i don't know what it is for!! i never get that red light when i put the phone in the charcher but when i do put my phone it the charger i don't get that logo that says that your phone is charging... i really need this sollution as quickly as possible cause i don't have another phone i got this problem after putting some songs on my phone... ps i don't know how to flash my phone so... thank you "Unlocker" |
03-28-2006, 04:28 | #38 (permalink) | |
Banned Join Date: Oct 2005 Location: inside forum
Member: 193336 Status: Offline Thanks Meter: 9 | Quote:
and convert back to red...... | |
03-28-2006, 04:29 | #39 (permalink) | |
u can use setool cracked with tp but i have not tested it. | |
03-28-2006, 08:33 | #40 (permalink) | |
Member: 248030 Status: Offline Thanks Meter: 29 | Quote:
Well, believe me I have...Other firmwares, and converted it back to red... I'm afraid I've also messed up GDFS, can I use V8000 gdfs and V800 erom files? | |
03-28-2006, 11:32 | #42 (permalink) | |
after flashing and other processes done it should be ok. | |
03-28-2006, 12:30 | #43 (permalink) | |
03-28-2006, 17:42 | #44 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | K750i Remains In Customisation Error Quote:
so i once again read the posts regarding k750i's in forum.i understood something. in one post named SE tutorial ,this is due to CID29 flash with sonics.(without using recover option).{my k750i set returned from another service centre.now when i read in ufs hwk it shows CID 36 BROWN.so i assumed it was originally CID29.}DUE TO THIS I ASSUMED U SAID ABOVE METHOD WAS NOT WORKING. CAN I REPAIR THIS IN SONICS USING FULL FLASH.I DOWNLOADED MAIN AND FS FILE FROM LANTE SITE.GDFS AND EROM FROM SOME LINKS. ONE MORE DOUBT,WHY SOME ONE SAYS SONICS DANGEROUS FOR SE FLASHING. THANK U Last edited by zonetrichur; 03-28-2006 at 18:33. | |
post all nokia software problem here, i will try to solved. | shahinahmed007 | Nokia Base Band 5 ( BB-5 ) | 145 | 11-04-2016 15:50 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
for morocan users post your box problem here | div_859 | FuriousGold | 2 | 06-04-2009 07:52 |
