Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 09-05-2008, 07:16   #1 (permalink)
    Member: 183501
    K750 white screen
    I have k750 white screen, and I'd try to flash it until done and still white screen.. somebody help me plzz..
    Open COM port OK
    ChipID:8040,EMP protocol:0301
    PHONE IS RED RETAIL PRODUCT
    FLASH CID detected:49
    Speed:921600
    Flash ID check:200D
    Flash props sent ok
    OTP LOCKED:1 CID:49 PAF:1 IMEI:35601801508808 CERT:RED
    FLASH CID:49 COLOR:RED
    Model:K750i
    Brand:Generic
    MAPP CXC article: R1CA021 prgCXC125954_CHINA_CL
    MAPP CXC version: R1CA021
    Language Package:APAC_1
    CDA article: CDA102337/101
    CDA version: R5A
    Default article: cxc125953
    Default version: R1CA021
    PROVIDER: 000-00
    SIMLOCKS NOT DETECTED
    USERCODE:0000
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed: 11 secs.
    Open COM port OK
    Speed:921600
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    THEN PRESS "READY"
    Open COM port OK
    Trying to launch embedded bootloader...
    INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
    Flash ID check:200D
    Flash props sent ok
    FOUND: R1AA008_CXC125954_CHINA_CL
    Restore from:R1AA008_CXC125954_CHINA_CL
    can't open file "D:\SONER-SETOOL\rest\R1AA008_CXC125954_CHINA_CL"
    writing D:\fIRMWARE SONER\k750\cid 49\k750_R1CA021_APAC1_CHINA_THAILAND_MAIN.cry
    CURRENT FLASH FILE CID:254
    SSW uses dynamic hash, dynamic hash len is:313
    Will flash 313 blocks...
    SSW loading returns:0
    writing D:\fIRMWARE SONER\k750\cid 49\k750_R1CA021_APAC1_FS.cry
    SSW uses dynamic hash, dynamic hash len is:153
    Will flash 153 blocks...
    Setting up GDFS...
    Writing simlocks...
    ALL UNLOCK/LOCK CODES SET TO "76844175"
    Signing...
    control keys complete.
    full sig complete.
    LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V23
    loader startup: executed
    loader GDFS startup: executed
    loader filesystem startup: executed
    loader unlock: executed
    writing tpa/preset/custom/C3_PCA_G3v2.cer
    writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    writing tpa/preset/custom/customize.xml
    writing tpa/preset/custom/DESKTOP_HOOK_2.itm
    writing tpa/preset/custom/Entrust.net Root Certificate.cer
    writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
    writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    writing tpa/preset/custom/GAMES_HOOK_3.itm
    writing tpa/preset/custom/GTE_CyberTrust_Root.cer
    writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    writing tpa/preset/custom/Root.cer
    writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
    writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    writing tpa/preset/custom/ThawtePremium.der
    writing tpa/preset/custom/ThawteServerCA.cer
    writing tpa/preset/custom/Utiroot.cer
    writing tpa/preset/custom/VeriSignClass3Root.cer
    writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Phone detached
    Elapsed: 788 secs.
    Old 09-05-2008, 07:18   #2 (permalink)
    Member: 199814
    Thanks Meter: 1,960
    it may be hardware issue. not software try to use usb cable to check phone working or not after than you will get sured idea hard or soft issue!
    Old 09-05-2008, 07:19   #3 (permalink)
    Member: 183501
    I've change lcd too.. but still white screen
    Old 09-05-2008, 07:20   #4 (permalink)
    aiyon_861's Avatar
    Member: 586707
    Thanks Meter: 129
    check your main +fs firmware flash it again with correct flash file
    Old 09-05-2008, 09:02   #5 (permalink)
    Member: 183501
    where i can download firmware k750 cid49? because in setool download area, cid49 not found..!
    Old 09-05-2008, 13:23   #6 (permalink)
    Member: 846111
    Thanks Meter: 11
    if the phone is in working condition try to re sold lcd connector and see weather the components around it are fine..
    Old 09-05-2008, 13:31   #7 (permalink)
    imam's Avatar
    Member: 82846
    Thanks Meter: 29
    Flash with this R1AA008 version
    br
    Old 09-05-2008, 16:13   #8 (permalink)
    anis_rainbow's Avatar
    Member: 597569
    Sonork: 100.1593870
    Thanks Meter: 271
    write gdfs then again try.........................................
    k750 white screen flashing mccm Cruiser Suite 17 05-10-2007 15:40
    HWK: K750 white screen, CDT 001 BROWN,WHATS THAT? shaak28 HWK 0 09-22-2006 17:21
    k750 white screen problem m.a.s.75 Sony Ericsson Hardware Repair 5 08-14-2006 20:29
    Repair Z530i - dead, ERROR: 302723, K750 white screen from ... Alkapone WotanServer 4 06-26-2006 20:38
    k750 white screen after flash it with usbsmat cobra02a SonyEricsson (USB-Smart) 0 05-02-2006 14:40
    Page generated in 0.18977 seconds with 9 queries
