Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 03-09-2010, 12:23   #1 (permalink)
    ..::Angel::..'s Avatar
    Member: 643472
    Sonork: 100.96901
    Thanks Meter: 16,589
    SE A2 Phones flashing with A2 uploader
    Hi,
    Flashing phones is not risky as long as you follow this tutorial. Still, do this at your own risk, I will not take responsibility in case you kill your phone and not follow the procedure correct.
    F.A.Q - Frequently Asked Questions:
    Q: What is A2uploader ?
    A: It is a software for flashing SE A2 based phones with USB!
    Q: Who made this software ?
    A: It is made by the_laser - thnx to laser
    Q: Which are A2 based phone? any list ?..
    A: Here is list of supported A2 phones:
    • V Series: V640
    • New SE phones: Jalou, Naite
    Q: Why i need to flash phone ?
    A: You can flash for Debrard - remove 3G,Vodafone logo etc, reset all data you modded, upgrade to increase perfomance, and for any software issue - blinking on sony logo, white light etc.
    Q: Where to get A2 firmwares for A2 uploader?..
    A: You can get firmwares from here. Also, You can search on google:
    Q: Where to download A2 uploader?
    A: You can download from here - A2 Uploader
    Q: Which firmware do I need? And how to check it is latest one?
    A: The latest firmware always has the highest number/character combination. e.g. R3EA037 is newer than R3DA031.
    If you want an unbranded phone you have to choose a generic firmware, this will be stated in the name. For example K850_R1FA037_MAIN_GENERIC_RED52.
    Always choose the right FS with your main firmware, these are the languages that are included in the different FS versions:
    Regions and languages for A2 phones:
    • ADRIATIC en - sq - bg - hr - fr - de - el - it - ro - ru
    • AMERICA en - pb - cf - nl - fr - xl - es
    • APAC-ANZ en - nl - fr - de - ms - id - tl - th - vi - zs
    • BALTIC en - et - lv - lt - ru
    • C-ASIA en - ar - az - fa - kk - ru - tr - uk
    • CENTRAL-EUROPE en - bs - hr - de - cs - hu - pl - sr - sk - sl
    • CHINA en - zs
    • FRANCE en - fr
    • HONG-KONG en - zh
    • HUTCH-WORLD en - da - de - it - sv
    • ISRAEL en - ar - az - fa - fr - tl - he - hi - ru
    • JAMAICA en - pb - nl - fr - es
    • NORDIC en - sq - ar - hr - da - fi - is - no - sv - tr
    • ORANGE-CH-SI en - fr - it - de
    • ORANGE-SIGN en - eu - ca - nl - fr - gl - de - pl - ro - sk - es
    • RUSSIA en - ru
    • S-ASIA-LEVAN en - ar - az - bn - fa - fr - tl - he - hi - ru
    • S-CENTR-AFR en - ar - nl - fa - fr - ha - de - ig - st - yo - zu - pt
    • S-E-EUROPE en - sq - bg - hr - el - hu - mk - ro - ru - sr
    • TELEFONICA en - eu - ca - fr - gl - pt - es
    • TAIWAN en - zt
    • T-MOB-INT en - hr - cs - nl - de - hu - mk - pl - sk - tr
    • VFE-LIVE-A en - eu - ca - nl - fr - gl - de - it - pt - es
    • VFE-LIVE-B en - bg - hr - cs - de - el - hu - sl - ro
    • WESTERN-EUROPE en - eu - ca - nl - fr - gl - de - pt - es - tr
    Your FS will be called K850_R1FA037_FS_HUTCH-WORLD_RED52. If you want any other language, just search the FS version where your language is included. Do not forget to download the right firmware for your phone. Flashing wrong firmware can be dangerous and can kill phone.
    You can see tutorial below:
    - Be sure to have the USB drivers installed, run GG setup that comes with the A2uploader archive.
    - Before we start your battery has to have enough power left, 50% or more. Flashing with a low battery percentage can kill your phone.
    Main screen: This is the main screen of A2uploader. With the identify button you can check your IMEI number, current firmware and device name.
    Add the firmware: Press the button add and select the main firmware file you just downloaded, it must have a *.mbn extension. Now pres sok, you’re back on the main screen and the firmware file is added to the box.
    Again press add and now select your FS file, this file must have *.fbn extension.
    Press flash: Press the flash button.
    - Now the program will ask you to hold C and connect your phone. Turn off the phone, hold "C" and now insert the USB cable while holding the "C" button. You can release the C button when new text appears in the big box on the left.
    - If holding C doesn't connect the phone connect while holding the 2 and 5 key, this applies for some A2 phone
    - A2uploader will now flash the firmware. During this process do NOT disconnect your phone.
    - After complete flashing process. A2 uploader will say “ready” at the bottom when the flashing process is done, now you can safely disconnect your phone from the USB cable.
    - Now we have to add custom pack files to make phone work!
    - You can get custompack from here
    Q: How to write custom files?
    A: Remove the two firmware files that are in the box and add the custompack you have downloaded (still ZIPPED) to misc files with the “” button.
    - Now press flash and connect the phone again holding C, like we did before. Then wait till A2 uploader says “Ready’ again and disconnect.
    That's all Special thnx to the_laser for making A2 uploader
    P.S. Disable your AV software before downloading. the_laser uses themidia encryption to prevent people stealing the sources and loaders of his A2uploader. AV software recognises this as virus/trojan horse but this is a false alarm. This software is completely safe.
    The Following 44 Users Say Thank You to ..::Angel::.. For This Useful Post:
    Old 03-09-2010, 12:54   #2 (permalink)
    oMeR_Rasheed's Avatar
    Member: 466635
    Sonork: 100.1614186
    Thanks Meter: 482
    Urdu file not included in these file"s
    b.r
    Sherry Mobiles
    Old 03-09-2010, 13:14   #3 (permalink)
    Member: 643472
    Sonork: 100.96901
    b.r
    Sherry Mobiles
    Hi,
    No it is not available - only Arabic and Farsi
    Old 03-17-2010, 15:31   #4 (permalink)
    Member: 1082967
    Sonork: chamith0659
    Thanks Meter: 11
    i want w890 firmware plzz send me link...i cant download ur website....
    Old 03-18-2010, 10:58   #5 (permalink)
    Member: 1264314
    i have update new firmware everything correctly but.. my phone still say phone lock, i lost the code so i update the new firm but its still ask for phone lock code, isnt when i update the new firm which it will delete everything and remove the phone lock code? i have try 0000 but no luck please tell me what i done wrong..
    Old 03-18-2010, 11:07   #6 (permalink)
    Member: 643472
    Sonork: 100.96901
    Hi,
    In this free tool, there is no script to reset user code to "0000" nor any button to unlock!
    You will need SETool to reset code!
    Old 03-18-2010, 12:00   #7 (permalink)
    FEATURE GSM™'s Avatar
    Member: 276151
    Sonork: 100.1577032
    Thanks Meter: 234
    hi i need all Arabic and Farsi firmware pls give links pls
    Old 03-18-2010, 12:05   #8 (permalink)
    Member: 643472
    Sonork: 100.96901
    Hello,
    Arabic and Farsi are avaialble in S-ASIA-LEVAN en - ar - az - bn - fa - fr - tl - he - hi - ru
    Old 03-21-2010, 11:26   #9 (permalink)
    Member: 643472
    Sonork: 100.96901
    Hi,
    You will need account in order to get firmwares for SE phones. Make new registeration.
    Old 03-21-2010, 17:42   #10 (permalink)
    Member: 1259661
    Sonork: tromadoli
    Thanks Meter: 3
    hi man i need network unlocking code for sony ericsson c510. ty
    Old 03-22-2010, 09:59   #11 (permalink)
    Member: 643472
    Sonork: 100.96901
    Hi,
    Use SETool and unlock your phone!
    Old 03-23-2010, 12:26   #12 (permalink)
    Member: 1249507
    Thanks Meter: 9
    hi i need all Arabic and Farsi firmware pls give links plz
    Old 03-23-2010, 23:29   #13 (permalink)
    Member: 714413
    coool thank's i did it know and he can't see sim card help plz.....
    Old 03-23-2010, 23:41   #14 (permalink)
    MYUNLOCKING's Avatar
    Member: 749969
    Sonork: 100.1581886
    Thanks Meter: 771
    why laser make this tool
    we all have setool..
    thats mean laser kills own box
    Old 03-24-2010, 10:55   #15 (permalink)
    Member: 643472
    Sonork: 100.96901
    Hi,
    Ask to laser not me.
    The Following User Says Thank You to ..::Angel::.. For This Useful Post:
    If phone flashed with unknown firmware by other parson then do it somratjisan Infinity-Box 0 12-16-2009 09:29
    BB5 phones flashed with errors. roberts Cyclonebox 5 10-01-2009 20:28
    Working Phones Flashed with Jaf LOCKED4EVER Nokia Hardware & Hardware Repair 0 09-08-2009 23:54
    successfull phone flashed with jtag Ramicom SAGEM JTAG UNLOCKER 3 01-19-2009 16:45
    Dead phone Flash with RSD LITE rk19801 Motorola Hardware Repair 5 08-01-2007 21:51
    Page generated in 0.25767 seconds with 9 queries
