Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
02-24-2005, 14:21 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 57
Member: 105340 Status: Offline Thanks Meter: 0 | V800 Dead after flashing now i can't even power on my phone. wat to do now? Client Version 11.0 Power on the phone! Detected SonyEricsson: Z1010/V800/Z500. Z1010 not support 921600 speed 460800 enabled! Status Ok, OTP Close, CID29, PAF1 IMEI: 354885-00-382506 Flash file CID:29 Flashing 259 blocks... address: 20D40000, block: 217/259 Sub block Not accepted Flash file CID:29 Execution Time - 00:05:41 Error: 0x005555 |
02-25-2005, 16:48 | #2 (permalink) |
Crazy Poster Join Date: Nov 2004 Location: NOTTINGHAMSHIRE Age: 49
Member: 92431 Status: Offline Thanks Meter: 0 | Get hold of the UFS tornado m8, a super wise investment if your in the trade. All is there to make your phone once again well...if ya having super trouble give us a ring, we'll help ya out at trade cost. www.theunlockshop.co.uk The Unlock Shop 14A High Street Mansfield Woodhouse Mansfield Notts, NG19 8AN 01623 650998 / 078630385010 |
02-28-2005, 22:00 | #3 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | How is UFS going to help with a V800 SonyEricsson phone? If you can, get back your credit from Davinci Team (they're very good like this) and make sure you're using the very latest client from them. Try a reflash and see if that helps. If not, contact Davinci Team for support. |
03-02-2005, 16:57 | #5 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Bangladesh
Member: 37349 Status: Offline Sonork: 100.1613413 Thanks Meter: 362 | Quote:
You should flash ur phone by new version of Davinci server client v12.5.so,just download the latest server client from Davinci download section & then get the flash file "V800_Flash_Recovery_R1D003_CID29.BIN" &then flash the phone & enjoy.but remember that u should make default flash finalization after flash.I hope it would be ok . best of luck. proxy_gsm | |
03-26-2005, 16:29 | #6 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: Australia Age: 45
Member: 97360 Status: Offline Thanks Meter: 0 | Quote:
Can someone confirm with me if they have ever debrand / flash their V800/V802SE with Davinci program . I got this mail from one of my friend and this is what Davinci responsed. One of my customer has also has problem flashing their firmware. ( CID issue) Last edited by kohler; 03-26-2005 at 16:46. | |
05-09-2005, 15:25 | #7 (permalink) |
Freak Poster Join Date: Mar 2005 Location: London Age: 41
Member: 123471 Status: Offline Thanks Meter: 0 | my v800 dead..after flashing with setool..at first it was the camera not functioning..then i reflash again with different z800 firmware..and it can t power on at all now..wat should i do now..thank you |
05-24-2005, 00:38 | #9 (permalink) |
Freak Poster Join Date: May 2005 Location: New Zealand
Member: 146818 Status: Offline Thanks Meter: 7 | have to flash v800EROM_RED after flashing the phone hi, every one, i had the exprience of flashing v800, every time after flashing the phone, most of phones would be dead, i have to flashed the v800erom_rom in the main file system, then flash the phone again, mostly the phone will work after that. ( i used sonicsbox to do above) |
10-31-2018, 09:01 | #10 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | help me RECOVERY MODE STARTED ChipID: 7100, EMP protocol: 0301 PHONE DOMAIN: "UNKNOWN" [00000000] SUPPORTED PHONE CID IS NOT DETECTED [0000] SPEED: 921600 REC: 041213 1451 MATCXC1325413_CERTLOADER R3S CHECKING OTP ... OTP: LOCKED:1 CID:36 PAF:1 IMEI:35488500915641 CERTIFICATE RESTORED. PLEASE REFLASH PHONE NOW Elapsed: 21 seconds CFG:000000000000 ChipID: 7100, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0036 SPEED: 921600 LDR: 050404 1011 LLECXC125871_PRODUCTION_ID_LOADER R1F OTP: LOCKED:1 CID:36 PAF:1 IMEI:35488500915641 CERT:RED LDR: 040422 0732 LLECXC1325413_CERTLOADER R3L Restarting ... ChipID: 7100, EMP protocol: 0301 PHONE DOMAIN: "UNKNOWN" [00000000] SUPPORTED PHONE CID IS NOT DETECTED [0000] skipping empty loader ... |
6300 dead after flash 6233 dead after flash | mobileZONE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 01:17 |
Dead 9210e Orange UK Dead after flashing :( | PhantomGSM | Trisha & Matrix Flasher | 4 | 05-06-2009 12:02 |
v800 dead after flash | visionmaster20 | Cruiser Suite | 1 | 05-22-2008 19:01 |
v800 dead after flash with hwk | nader06 | Sony Ericsson | 0 | 03-28-2007 16:24 |
