Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
02-11-2010, 14:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Sony ericsson t715 cid53 unlocked with help Note: if cid53 then 1 credit, if cid52 or less then free SELECT: signed mode enable alternative security bypass connect via usb cable by pressing 2+5 info: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35662703XXXXXX] OTP LOCKED:1 CID:53 PAF:1 IMEI:35662703XXXXXX CERT:RED LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082 LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082 Model (from GDFS):T715 MAPP CXC article: R1GA026 prg1222-7136_HUTCHISON_AM MAPP CXC version: R1GA026 Language Package: HUTCH-WORLD CDA article: 1227-0475 CDA version: R9A Default article: 1220-5169 Default version: R1GA026 PROVIDER: MULTIPLE Network LOCKED Elapsed: 10 secs. credit check: SIGNED MODE (USING SERVER) CFG:110000000000 SERVER CREDITS LEFT/USED: 27/3 CARD COUNTERS: FLASH 528, UNLOCK 272 Elapsed: 2 secs. unlock log: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35662703XXXXXX] OTP LOCKED:1 CID:53 PAF:1 IMEI:35662703XXXXXX CERT:RED LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082 LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082 GOT CHALLENGE GOT SEED671332E3580137135B03C13 GOT RESPONSE signoff response ok P96 AUTH PASSED DEVICE KEY:1F5C3E1CA866D8C77D78C10DE8EEAEC7 (0) RESTARTING... ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35662703XXXXXX] OTP LOCKED:1 CID:53 PAF:1 IMEI:35662703XXXXXX CERT:RED LDR:2009-04-21 18:39 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:40 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A081 GOT CHALLENGE GOT SEED:C32BED0D3580137135B03C13 GOT RESPONSE signoff response ok P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35662703XXXXXX] OTP LOCKED:1 CID:53 PAF:1 IMEI:3566270XXXXXXX CERT:BROWN LDR:2009-06-26 16:10 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A082 LDR:2009-06-26 16:11 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A082 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "18716434" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 41 secs. credit check: SIGNED MODE (USING SERVER) CFG:110000000000 SERVER CREDITS LEFT/USED: 26/4 CARD COUNTERS: FLASH 528, UNLOCK 273 Elapsed: 3 secs. MIANLINKS |
03-02-2010, 13:21 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | hi, guys i unlocked T715 with setool.....it takes credit... go to SEMC A2 tab Select T707 Select 2 option from setting Sign mode Ful unlock instead of user code |
The Following User Says Thank You to roney_nexus For This Useful Post: |
03-03-2012, 15:43 | #4 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Lahore Pakistan. Age: 38
Member: 1284347 Status: Offline Sonork: 100.1592292 Thanks Meter: 977 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35662703617530] OTP LOCKED:1 CID:53 PAF:1 IMEI:35662703617530 CERT:RED LDR:2009-10-26 13:51 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A087 LDR:2009-10-26 13:52 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A087 GOT SEED:0DEDB7853580137135A0C396 P96 AUTH PASSED RESTARTING ... ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35662703617530] OTP LOCKED:1 CID:53 PAF:1 IMEI:35662703617530 CERT:RED DEVICE KEY:6BB2B4D3FF8A1CA4FB59BB5DFF264B5F (1) LDR:2009-10-26 14:03 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A087 LDR:2009-10-26 14:04 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A087 GOT SEED:E9F90F923580137135A0C396 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE ... RESTARTING ... ChipID:E900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35662703617530] OTP LOCKED:1 CID:53 PAF:1 IMEI:35662703617530 CERT:BROWN LDR:2010-03-02 18:04 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A096 LDR:2010-03-02 18:04 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A096 WRITING SEMCBOOT ... PREPARING SECURITY ... PHONE DOMAIN: "RED" WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "82342643" SIGNING ... DEVICE KEY RESTORED Unlock DONE Elapsed: 38 secs. |
thanks to setool team T715 cid53 unlock done few second free | kadricom | SETool2 | 6 | 02-16-2011 10:38 |
Sony Ericsson T105 not unlock with Se-tool but UB Done it. | mali_comm | Universalbox | 1 | 03-26-2010 10:19 |
sony ericsson t715 IMEI | Bypx | Sony Ericsson | 0 | 02-19-2010 15:35 |
Sony Ericsson W302 Succesfully Unlock With Log | jubaer | Universalbox | 4 | 02-24-2009 22:03 |
Unlock Sony Ericsson T610/T630 RSA with N-box? | laxxe | n-Box | 10 | 04-08-2005 01:50 |
