Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
11-06-2010, 21:57 | #16 (permalink) |
Registered User Join Date: Oct 2005 Location: e g y p t Age: 43
Member: 194178 Status: Offline Sonork: 100.1594302 Thanks Meter: 34 | Code: 22:55:28 SE S1 Flasher & Unlocker v3.00 by Cruiser Team 22:55:28 Initializing... ! 22:55:28 1. Choose the phone model ! 22:55:28 2. For flashing, select flash files and additional options ! 22:55:28 3. Double-click on the appropriate device (serial cable) ! 22:55:28 - or connect the phone via USB while holding its C button 22:55:43 Connecting via Generic FTDI Cable (COM5)… 22:55:43 Device driver version: 2.6.0.0 22:55:43 Device driver date: 10-22-2009 ! 22:55:43 Connect the phone now 22:55:43 Connecting to the baseband CPU... 22:55:53 Entering baseband CPU service mode... 22:55:53 Phone type: W395 22:55:54 CDA info: 1225-0220 R2A 22:55:54 Phone software: 1217-5563 R1EA012 22:55:54 IMEI: 3590240345**** 22:55:54 Sending loader... E 22:55:56 Error: 0x154185E0 E 22:55:56 Error: 0xC41C185B E 22:55:56 Failed! ! 22:55:56 Please disconnect battery and cable from the phone! ! 22:55:56 To report errors right-click this window |
01-11-2011, 03:42 | #17 (permalink) |
No Life Poster Join Date: Apr 2008 Location: TOKYO JAPAN Age: 43
Member: 747968 Status: Offline Sonork: 100.1621353 Thanks Meter: 444 | Code: 09:56:07 SE S1 Flasher & Unlocker v3.00 by Cruiser Team 09:56:07 Initializing... ! 09:56:08 1. Choose the phone model ! 09:56:08 2. For flashing, select flash files and additional options ! 09:56:08 3. Double-click on the appropriate device (serial cable) ! 09:56:08 - or connect the phone via USB while holding its C button 09:56:16 Connecting via SEMC USB Flash Device (USB3)… 09:56:16 Device driver version: 2.0.0.4 09:56:16 Device driver date: 9-12-2007 09:56:17 Connecting to the baseband CPU... 09:56:17 Entering baseband CPU service mode... 09:56:17 Phone type: W395 09:56:17 CDA info: 1219-9354 R8A 09:56:17 Phone software: 12175563 R1CB011 09:56:17 IMEI: 35236203359053 09:56:17 Sending loader... 09:56:21 Reading TA… 09:56:24 Communicating with server… ! 09:56:28 News: ----------------------------------------------------------------- ! 09:56:28 News: Try OMNIUS, new Sony Ericsson service tool! ! 09:56:28 News: http://www.omnius-server.com/ ! 09:56:29 News: ----------------------------------------------------------------- ! 09:56:29 News: Your consumption level is: Level 3 (Skilled) 09:56:30 Remainig credit (supreme): 7.34 09:56:34 Searching... 09:56:35 Unlocking… 09:56:37 Remainig credit (supreme): 7.18 09:56:37 Turning off the phone... 09:56:39 Done. ! 09:56:39 Please disconnect battery and cable from the phone! |
01-11-2011, 05:05 | #18 (permalink) | |
Member: 747968 Status: Offline Sonork: 100.1621353 Thanks Meter: 444 | Quote:
1. clean up all pin of your phone 2. clean up pin cable also 3. turn on the phone then connect the cable ( if the cable need driver cancel it ) 4. turn of the phone, take out the battery 5. make sure your credit is available 6. make sure your internet connection running 7. press C then connect the cable 8. holla your phone unlocked | |
Sony ericsson w580i unlock successfully with rj45 cable | shmily | SETool2 | 0 | 11-17-2009 14:02 |
unlock sony ericsson w395 done | djlicks | Universalbox | 3 | 08-02-2009 07:24 |
Soni Ericsson T280i Unlock Ok By Infinity | genci titi 2002 | Infinity-Box | 5 | 08-15-2008 14:43 |
Sony Ericsson K320i Unlock Succesfull With Dream Box | Sahil2007 | DreamBox | 1 | 04-20-2008 12:27 |
