Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
12-31-2008, 02:12 | #1 (permalink) |
Registered User Join Date: Oct 2006
Member: 376867 Status: Offline Thanks Meter: 10 | se k800i not unlock Welcome to SEtool2 ( LITE edition ) v 1.11 supported DB2010/DB2012 CID49/50/51/52, DB2020 CID49/51/52 Loaded 51 flash descriptors if you like LITE edition - please visit www.setool.net and buy FULL. FILE RECOGNIZED AS CUSTOMIZATION PACKAGE. CDA:CDA102568/3 MODEL:HB1-06 Generic VARIANT:S_E_EUROPE LANGUAGE: EN LANGUAGE: HR LANGUAGE: HU LANGUAGE: SR LANGUAGE: SL LANGUAGE: SQ ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:****** CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok writing C:\Users\sus\Desktop\se1\K800_R8BF003_MAIN_GENERIC _WI_RED52.mbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing C:\Users\sus\Desktop\se1\K800_R8BF003_FS_S_E_EUROP E_RED52.fbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:4740 Will flash 237 blocks... SSW loading returns:0 CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 loader startup: executed loader filesystem startup: executed loader GDFS startup: executed Writing package... chdir: 2 Directory not found, attempt to create chdir: 2 chdir: 2 chdir: 2 Directory: HB1-06_Generic_CDA102568_3_R4A_GENERIC_S_E_EUROPE/tpa/preset/custom/ CONTENT_DOWNLOAD_HOOK.itm (10240) Customize.xml (1146) FM_PICTURES_HOOK_3.itm (10240) FM_SOUNDS_HOOK_3.itm (10240) FM_THEMES_HOOK_3.itm (10240) FM_VIDEOS_HOOK_3.itm (10240) GAMES_HOOK_3.itm (10240) MEDIA_PLAYER_HOOK_3.itm (10240) ORG_APPLICATIONS_HOOK_3.itm (10240) preloaded_config.xml (78607) SETT_RINGTONE_HOOK_1.itm (10240) SETT_SCREENSAVER_HOOK_1.itm (10240) SETT_STARTSHOW_HOOK_1.itm (10240) SETT_WALLPAPER_HOOK_1.itm (10240) VIDEO_PLAYER_HOOK_1.itm (10240) Phone detached Elapsed:406 secs. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:******* CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 Processing part2... Processing part3.... OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601741343 CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" HOLD "C" BUTTON AND ATTACH PHONE CID52 BYPASS PROCEDURE FINISHED ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 Flash ID check:2019 Flash props sent ok writing C:\Users\sus\Desktop\se1\K800_R8BF003_MAIN_GENERIC _WI_RED52.mbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 Going to execute VKP script.... Starting to process VKP patch script: E:\mobile unlocking\DB2020_Free_unlocking\setool2liteV1.11\q amaker\quick_access_K800_R8BF003.vkp VKP script loaded OK. Lines: 1637 Patch structure created OK. Determining blocks to read... New block #0000 added: $44140000 New block #0001 added: $45C80000 Blocks selected OK. Reading blocks: 2 Blocks readed to memory OK. Checking contents... Blocks patched OK. Start writing... Block 0 written Block 1 written VKP script executed OK Elapsed:714 secs. Going to execute VKP script.... Abort all operations. Elapsed:6 secs. Going to execute VKP script.... ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... INT LDR:quick access patch by den_po FLASH CID:52 COLOR:RED OTP LOCKED:1 CID:49 PAF:1 IMEI:****** CERT:RED LDRB2020 LOADER FOR SETOOL2 Starting to process VKP patch script: E:\mobile unlocking\DB2020_Free_unlocking\SIMLockPatchGen\vk p\Remove_SIM_lock_K800_R8BF003.vkp VKP script loaded OK. Lines: 6 Patch structure created OK. Determining blocks to read... New block #0000 added: $44740000 Blocks selected OK. Reading blocks: 1 Blocks readed to memory OK. Checking contents... Elapsed:41 secs. * i followed this http://forum.gsmhosting.com/vbb/show...+flash&page=22 |
12-31-2008, 15:26 | #4 (permalink) |
Member: 376867 Status: Offline Thanks Meter: 10 | thanks mate.. got phone back but it is still not unlock... Welcome to SEtool2 ( LITE edition ) v 1.11 supported DB2010/DB2012 CID49/50/51/52, DB2020 CID49/51/52 Loaded 51 flash descriptors if you like LITE edition - please visit www.setool.net and buy FULL. FILE RECOGNIZED AS CUSTOMIZATION PACKAGE. CDA:CDA102568/3 MODEL:HB1-06 Generic VARIANT:S_E_EUROPE LANGUAGE: EN LANGUAGE: HR LANGUAGE: HU LANGUAGE: SR LANGUAGE: SL LANGUAGE: SQ ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:******* CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok writing C:\Users\sus\Desktop\se1\K800_R8BF003_MAIN_GENERIC _WI_RED52.mbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing C:\Users\sus\Desktop\se1\K800_R8BF003_FS_S_E_EUROP E_RED52.fbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:4740 Will flash 237 blocks... SSW loading returns:0 CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 loader startup: executed loader filesystem startup: executed loader GDFS startup: executed Writing package... chdir: 2 Directory not found, attempt to create chdir: 2 chdir: 2 chdir: 2 Directory: HB1-06_Generic_CDA102568_3_R4A_GENERIC_S_E_EUROPE/tpa/preset/custom/ CONTENT_DOWNLOAD_HOOK.itm (10240) Customize.xml (1146) FM_PICTURES_HOOK_3.itm (10240) FM_SOUNDS_HOOK_3.itm (10240) FM_THEMES_HOOK_3.itm (10240) FM_VIDEOS_HOOK_3.itm (10240) GAMES_HOOK_3.itm (10240) MEDIA_PLAYER_HOOK_3.itm (10240) ORG_APPLICATIONS_HOOK_3.itm (10240) preloaded_config.xml (78607) SETT_RINGTONE_HOOK_1.itm (10240) SETT_SCREENSAVER_HOOK_1.itm (10240) SETT_STARTSHOW_HOOK_1.itm (10240) SETT_WALLPAPER_HOOK_1.itm (10240) VIDEO_PLAYER_HOOK_1.itm (10240) Phone detached Elapsed:397 secs. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:---------- CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok writing E:\mobile unlocking\DB2020_Free_unlocking\XS++\se1\K800_R8BF 003_MAIN_GENERIC_WI_RED52.mbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 Going to execute VKP script.... Enable alternative security bypass !!! Starting to process VKP patch script: E:\mobile unlocking\DB2020_Free_unlocking\setool2liteV1.11\q amaker\quick_access_K800_R8BF003.vkp VKP script loaded OK. Lines: 1637 Patch structure created OK. Determining blocks to read... New block #0000 added: $44140000 New block #0001 added: $45C80000 Blocks selected OK. Reading blocks: 2 Block @ $44140000 read error. Have only: 00000000 bytes Elapsed:365 secs. Going to execute VKP script.... ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:3 CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok Starting to process VKP patch script: E:\mobile unlocking\DB2020_Free_unlocking\SIMLockPatchGen\vk p\Remove_SIM_lock_K800_R8BF003.vkp VKP script loaded OK. Lines: 6 Patch structure created OK. Determining blocks to read... New block #0000 added: $44740000 Blocks selected OK. Reading blocks: 1 Block @ $44740000 read error. Have only: 00000000 bytes Elapsed:32 secs. |
SE t303 not unlock | sergioems | Universalbox | 3 | 07-06-2009 20:53 |
SE w595 not unlocking | sms422 | Universalbox | 4 | 04-02-2009 18:19 |
SE K800i CID53 unlock | evaireland | Cruiser Suite | 1 | 09-09-2008 05:07 |
k800i not unlocked | kanwal | Cruiser Suite | 13 | 12-05-2007 13:30 |
SE-clip not unlocking z200 or T106 even after update? | sofakingcool420 | Sony Ericsson | 1 | 08-25-2004 20:43 |
