Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 08-03-2004, 20:10   #1 (permalink)
    Member: 10483
    Thanks Meter: 23
    T637 with no signal after unlock it
    HI,
    I have a T637 and I unlock it with div but use T630.
    Now, T637 switch on but no network, no signal.
    Is there a specific soft who do T637?
    SOmebody can tell me on wich band does it work.
    Thks a lot
    Old 08-04-2004, 09:24   #2 (permalink)
    danielkhaw's Avatar
    Member: 10977
    Thanks Meter: 55
    T637 is 900/1800/1900mhz
    Old 08-04-2004, 13:46   #3 (permalink)
    Member: 31934
    Originally Posted by gsmnice
    HI,
    Thks a lot
    T637 is 850/1800/1900mhz, T630 is 900/1800/1900.
    try to using Div 3.1 and use "Rebuild SP Area Using OTP IMEI" and make sure you used the 850/1800/1900 version to do the rebuild with or the Div 4.0 you can find the T637 and use "Rebuild SP Area Using OTP IMEI", hope this will help.
    Old 08-05-2004, 21:21   #4 (permalink)
    Member: 10483
    Thanks Meter: 23
    Thks for your help
    But there is no version T637 on div 3.1 just T630.
    So always no signal on my t630.
    THere is an option to choose band on the phone or not.
    If yes, on wuich menu.
    THks a lot
    Old 08-06-2004, 07:44   #5 (permalink)
    Member: 31934
    Thks for your help
    THks a lot
    Div 4.0 will have the T637, I unlocked and unband my phone with the Div 4.0.
    use search for Div 4.0, http://laser.cellular-support.com/divlpt4.exe
    hope that will help.
    Old 08-10-2004, 17:06   #6 (permalink)
    evan_silbert's Avatar
    Member: 21920
    Thanks Meter: 10
    Where are you trying to use the t637? If it is on a 900MHz network it will not find signal!!
    Old 08-14-2004, 01:42   #7 (permalink)
    Member: 10483
    Thanks Meter: 23
    Thks a lot, div 4.0 work perfect.
    So unlockers check before to see if it s T630 or t637.
    No my phone find again network.
    Thks
    error unlock nokia 1112 sw 6.46 phone is no signal after unlock residentdenuevo MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-16-2010 08:26
    nokia 2610 no signal after unlock with cyclone. boliargsm Cyclonebox 14 02-05-2010 22:40
    W810 no signal after unlocking with cruiser akifsadique Cruiser Suite 11 05-29-2007 09:25
    GD67 no signal after unlock!!! GSM SNIPER Panasonic 2 05-20-2004 20:07
    3310 no signal after unlocking Erik Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-16-2001 02:33
    Page generated in 0.16899 seconds with 9 queries
