Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
02-08-2010, 06:10 | #19 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 241673 Status: Offline Thanks Meter: 8 | may be can help for updating damage phone http://www.fastgsm.com/en/sonyericss...oftware-update |
The Following User Says Thank You to sixgems For This Useful Post: |
03-09-2010, 10:49 | #23 (permalink) |
Insane Poster Join Date: Sep 2007 Location: PRN
Member: 585270 Status: Offline Thanks Meter: 17 | I have fix my Phone , flleshed whith files T717 and then unlock whith select model T707 and your Phone whill be done . |
The Following User Says Thank You to engojboy For This Useful Post: |
03-24-2010, 20:14 | #26 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 141927 Status: Offline Thanks Meter: 27 | Free no need log in v1.01 3/25/2010 12:38:38 AM RUNNING v 1.01/UNI 3/25/2010 12:38:38 AM CARD SERIAL 00029102 3/25/2010 12:39:23 AM SIGNED MODE (USING SERVER) 3/25/2010 12:39:23 AM PRELOADER SECURITY BYPASS ENABLED 3/25/2010 12:39:23 AM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 3/25/2010 12:39:23 AM CFG:101001000000 3/25/2010 12:39:37 AM ChipID900,EMP protocol:0401 3/25/2010 12:39:37 AM BOOTROM MODE DETECTED 3/25/2010 12:39:37 AM OTP DBG: [1,53,1,35697903250341] 3/25/2010 12:39:40 AM OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903250341 CERT:BROWN 3/25/2010 12:39:41 AM DEVICE KEY:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (0) 3/25/2010 12:39:42 AM LDR:2009-04-21 18:27 1207-6247_DB3200_RESET_LOADER_ACC_SDRAM_R2A081 3/25/2010 12:39:43 AM LDR:2009-04-21 18:28 1207-6248_DB3200_RESET_LOADER_APP_SDRAM_R2A081 3/25/2010 12:39:50 AM GOT SEED:B9F98E7F3580737235501E3D 3/25/2010 12:39:51 AM P96 AUTH PASSED 3/25/2010 12:39:51 AM RESETTING SECURITY TO FACTORY STATE... 3/25/2010 12:39:52 AM RESTARTING... 3/25/2010 12:39:54 AM ChipID900,EMP protocol:0401 3/25/2010 12:39:54 AM BOOTROM MODE DETECTED 3/25/2010 12:39:54 AM OTP DBG: [1,53,1,35697903250341] 3/25/2010 12:39:56 AM OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903250341 CERT:BROWN 3/25/2010 12:39:57 AM LDR:2009-07-31 10:49 1207-6245_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2A084 3/25/2010 12:39:58 AM LDR:2009-07-31 10:50 1207-6246_DB3200_PRODUCTION_LOADER_APP_SDRAM_R2A084 3/25/2010 12:39:58 AM WRITING SEMCBOOT... 3/25/2010 12:39:59 AM PREPARING SECURITY... 3/25/2010 12:39:59 AM WRITING CLEAR SIMLOCK UNITS... 3/25/2010 12:39:59 AM ALL UNLOCK/LOCK CODES SET TO "44751083" 3/25/2010 12:40:01 AM CHANGING DOMAIN TO "CURRENT" 3/25/2010 12:40:01 AM SIGNING... 3/25/2010 12:40:02 AM DEVICE KEY RESTORED 3/25/2010 12:40:02 AM Unlock FINISHED 3/25/2010 12:40:02 AM Elapsed: 39 secs. |
The Following User Says Thank You to pugazhendhi For This Useful Post: |
03-26-2010, 23:16 | #27 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | so i dont need no file in v1.01?.... just select t707 and signed mode n unlocked??.. i dont wana kill a phone... Quote:
The Following User Says Thank You to jusmejose For This Useful Post: |
03-26-2010, 23:28 | #28 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | RUNNING v 1.01/UNI CARD SERIAL 00131194 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903127453] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903127453 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 Model (from GDFS):TM717 MAPP CXC article: R1FC011 prg1218-5230_TMOUS_ET MAPP CXC version: R1FC011 Language Package: TMO-US CDA article: 1223-8973 CDA version: R16A Default article: 1217-3366 Default version: R1FC011 PROVIDER: MULTIPLE Network LOCKED Elapsed: 19 secs. CFG:000000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903127453] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903127453 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Unlock FINISHED Elapsed: 10 secs. |
04-01-2010, 09:38 | #29 (permalink) |
Banned Join Date: Jun 2009
Member: 1058944 Status: Offline Sonork: 100.1582347 Thanks Meter: 218 | Hi Brother, Activated SE TOOL did it like charme and without logs. USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903310293] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903310293 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 Model (from GDFS):TM717 MAPP CXC article: R1FC011 prg1218-5230_TMOUS_ET MAPP CXC version: R1FC011 Language Package: TMO-US CDA article: 1223-8973 CDA version: R16A Default article: 1217-3366 Default version: R1FC011 PROVIDER: MULTIPLE Network LOCKED Elapsed: 10 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903310293] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903310293 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 GOT SEED:0D0E652A358073723550C14B P96 AUTH PASSED RESTARTING... ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903310293] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903310293 CERT:RED DEVICE KEY:3B75CA847A66111B6F3530E6946605C4 (0) LDR:2009-04-21 18:27 1207-6247_DB3200_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:28 1207-6248_DB3200_RESET_LOADER_APP_SDRAM_R2A081 GOT SEED:1080393F358073723550C14B P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903310293] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903310293 CERT:BROWN LDR:2009-07-31 10:49 1207-6245_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:50 1207-6246_DB3200_PRODUCTION_LOADER_APP_SDRAM_R2A084 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "25764061" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 47 secs. thanks SE TOOL. Br, Raja |
The Following User Says Thank You to GSM-STUDENT For This Useful Post: |
04-02-2010, 22:02 | #30 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | RUNNING v 1.01/UNI CARD SERIAL 00131194 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903127453] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903127453 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 Model (from GDFS):TM717 MAPP CXC article: R1FC011 prg1218-5230_TMOUS_ET MAPP CXC version: R1FC011 Language Package: TMO-US CDA article: 1223-8973 CDA version: R16A Default article: 1217-3366 Default version: R1FC011 PROVIDER: MULTIPLE Network LOCKED Elapsed: 11 secs. CFG:000000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903127453] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903127453 CERT:RED LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Unlock FINISHED Elapsed: 9 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:101000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903127453] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903127453 CERT:RED DEVICE KEY:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (0) LDR:2009-04-21 18:27 1207-6247_DB3200_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:28 1207-6248_DB3200_RESET_LOADER_APP_SDRAM_R2A081 GOT SEED:B13C6E793580737235D01D1F P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,53,1,35697903127453] OTP LOCKED:1 CID:53 PAF:1 IMEI:35697903127453 CERT:BROWN LDR:2009-07-31 10:49 1207-6245_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2A084 LDR:2009-07-31 10:50 1207-6246_DB3200_PRODUCTION_LOADER_APP_SDRAM_R2A084 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "48472354" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 31 secs. |
The Following 2 Users Say Thank You to jusmejose For This Useful Post: |
TM717 unlock drivers | gophone | SETool2 | 1 | 06-13-2010 16:56 |
BlackBerry 8520 unlock help needed | derk | FuriousGold | 3 | 04-08-2010 11:37 |
iphone unlock help for bigners | Mind Power | iPhone 2 / iPhone 3G / iPhone 3GS | 5 | 03-29-2010 17:05 |
Tm717 unlock done | baooshe2 | Cruiser Suite | 0 | 03-24-2010 10:49 |
