Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
11-04-2009, 16:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1142158 Status: Offline Sonork: 123456789 Thanks Meter: 25 | G900 still hanging after flash this phone is hanging on start and flash it but still hanging after flash im tick 2 options only sign mode customize phone after flash ----------------------------------------------------------- PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM231, SLAVE on COM232 PDA EROM VERSION: 1202-0238 R1A01 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:115200 FLASH ID:2010 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602441578 CERT:RED FLASH CID:53 COLOR:RED phone model (from GDFS): G900 part number: FAD-3022019-BV Phone part version: 1203-6566 R9N002 Organizer part version: 1203-8784 R6K842 CDA part version: 1204-3155 R6K836 CCPU part version: 1203-6568 R5C01 USERCODE:0000 Elapsed: 54 secs. SIGNED MODE (USING SERVER) CFG:100100000000 writing "D:\02-SE TOOL BOX 3\Firmware\G900\G900_MR2_ARABIC1__R9N002_R1F_R6K84 2_R6K836.zip" Processing package D:\02-SE TOOL BOX 3\Firmware\G900\G900_MR2_ARABIC1__R9N002_R1F_R6K84 2_R6K836.zip detected MASTER on COM231, SLAVE on COM232 PDA EROM VERSION: 1202-0238 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM231, SLAVE on COM232 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:115200 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602441578 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:2010 Processing CCPU files PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader startup: executed loader GDFS startup: executed loader unlock: executed Writing GDFS var 0002/06D6/0001 Success Writing GDFS var 0002/06D4/0005 Success Writing GDFS var 0002/06D3/000F Success Writing GDFS var 0000/0094/0001 Success Writing GDFS var 0002/079E/0053 Success Elapsed: 1175 secs. ---------------------------------------------------- what is the error |
11-05-2009, 16:29 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: egypt Age: 43
Member: 158471 Status: Offline Sonork: 100.1588029 Thanks Meter: 120 | this problem after flash and phone woks ok before flash and need to change lang only so you mean before flash must take of lcd like some motorola when i unlock or what do you mean so problem phone after flash power on and write lang ar en ask select lang when i slected any lang write (note.when selectinga lang for the first time in setup wizard all other lang will be deleted....) and two select yes and no now i con not selected any choose and i can go back by keboard |
11-06-2009, 04:14 | #7 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Unknown location
Member: 1092212 Status: Offline Thanks Meter: 111 | Quote:
G900 still hanging after flash welcome this phone is hanging on start and flash it but still hanging after flash im tick 2 options only sign mode customize phone after flash i give this post ans but your prob is diff so u must tick format gdfs when writing bro....... | |
11-08-2009, 15:27 | #8 (permalink) |
Member: 1142158 Status: Offline Sonork: 123456789 Thanks Meter: 25 | im flashing it with 2 options only but problem not solved next time im flashing it with 2 options and format gdfs when writing but problem not solved its stil hanging in language opening/setup i think its big problem |
04-23-2010, 12:46 | #11 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | g900 hang after flashing Code: CFG:000000000000 writing "E:\Setool\SETOOL\SSW Format\g900\G900_R6K842_S_TEL_SG_1208_6548_R14A.zip" Processing package E:\Setool\SETOOL\SSW Format\g900\G900_R6K842_S_TEL_SG_1208_6548_R14A.zip detected MASTER on COM91, SLAVE on COM92 PDA EROM VERSION: 1202-0238 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM91, SLAVE on COM92 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602056122 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 8964 Processing CCPU files PROCESSING: R5C01_R8_CCPU_FS_R5C01__RED_CID53_DB2001.software CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9N002_R8_CCPU_SW_R9N002__RED_CID53_DB2001.software CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM91, SLAVE on COM92 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602056122 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: P1A_GD_EncryptionAlgorithm_A5_v.gdfs Writing GDFS var 0000/0094/0001 PROCESSING: R14A_GDF__1208_6548.gdfs Writing GDFS var 0000/0094/0001 Writing GDFS var 0002/06D3/000F Writing GDFS var 0002/06D4/0005 Writing GDFS var 0002/06D6/0001 PROCESSING: R14A_PUQ__GDF__1208_6548_R6K842_154153554.gdfs Writing GDFS var 0002/079E/0051 Elapsed: 1530 secs. |
04-25-2010, 08:03 | #13 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | G900 still hanging after flash Code: G900 still hanging after flash reset phone and check. if same - check hardware.u change LCD...try to result me thx... |
g900 more hangs after software upgrade | pankajkukar2 | SETool2 | 5 | 02-26-2010 04:43 |
ZV10 Still Hanging after flash | dannyogolo | UST Pro II | 0 | 11-24-2006 17:11 |
R320 in hang after flash language | Deltas | Old Ericsson Phones & Sony Phones | 16 | 03-20-2003 18:59 |
c35i still locked after flash ! | Zion | x1x to x45/x50 | 10 | 07-09-2001 20:15 |
