w200 cid51 plz help i have w200 set when i on set is on light blue show it mean software problem i want to flash with setool show this error i have change other battery but same problem solution ..................... |
try to make identify and post here |
post logs then i will try bro thx... |
yes without a log none can't help you |
solve my problem thank's all brother for helpping |
System diagnostics passed. Version 13.21 ready! [ --- Attach to Phone --- ] Connecting via Interceptor USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 51 Phone color: Brown Flash certificate: A1_DB2010_51_BROWN Terminating threads... All threads terminated. |
v0.915051/UNI CARD SERIAL: 00025326 Loaded 51 flash descriptors CFG:000000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35575902903005 CERT:BROWN FLASH CID:51 COLOR:BROWN can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 62 secs. |
that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
