Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 07-07-2008, 19:14   #1 (permalink)
    Member: 786417
    Unhappy W200i 5 locks closed after unlock, please help!
    Hello,
    please help me, i try to unlock a Sony Ericsson W200i CID51 with SE Full unlocker v2.11 and cruiser supreme credit but now all 5 locks are closed and i lost 1 credit. I tryed it 3 times, no change.
    18:20:16 SE Full Unlocker v2.11 by Cruiser Team 18:20:16 Initializing...! 18:20:16 1. Please see the documentation first (a PDF installed with the application)! 18:20:16 2. Make sure the appropriate phone modem drivers are installed! 18:20:16 3. Fill in the connection settings under settings tab! 18:20:16 4. Turn the phone ON! 18:20:16 5. Connect the phone… 18:21:14 Connecting via SEMC WMC Device (COM11, COM10)… 18:21:14 Starting communication... 18:21:14 Communicating with server… 18:21:18 Remainig credit (supreme): 3.00 18:21:18 Restarting phone … 18:21:43 Connecting via SEMC USB Flash Device (USB2)… 18:21:43 Device driver version: 2.1.0.0 18:21:43 Device driver date: 3-20-2008 18:21:43 Starting communication... 18:21:43 Connecting to the baseband CPU... 18:21:43 Entering baseband CPU service mode... 18:21:44 Detected chipset: DB2012 18:21:44 Boot mode: EROM 18:21:46 Initializing loader... 18:21:46 Initializing GDFS access... 18:22:11 Communicating with server… 18:22:15 Connecting to the baseband CPU... 18:22:15 Restarting phone … 18:22:37 Starting communication... 18:22:39 Communicating with server… 18:22:47 Remainig credit (supreme): 3.00 18:22:47 Done. 18:22:47 The phone has been successfully unlocked.! 18:22:47 Disconnect cable and restart the phone (turn it off and then turn it on)
    Old 07-08-2008, 07:02   #2 (permalink)
    Member: 232607
    Sonork: 100.1585040
    Thanks Meter: 260
    do it with dream box all ok
    thanx
    Old 07-08-2008, 07:23   #3 (permalink)
    raezak's Avatar
    Member: 260632
    Thanks Meter: 639
    write back the gdfs back up ....... or do full unlock
    br
    Old 07-08-2008, 07:28   #4 (permalink)
    Member: 472482
    Thanks Meter: 105
    Why do it with log??? Flash again with cid 51 flash, write script to flash cid 52, and after unlock with bypass sec mode with java.
    The Following User Says Thank You to dominik1 For This Useful Post:
    Old 07-08-2008, 08:40   #5 (permalink)
    aleem26's Avatar
    Member: 241661
    Thanks Meter: 265
    w 200 unlock by setool
    v0.914037/UNI
    CARD SERIAL: ggggggg
    Loaded 51 flash descriptors
    ChipID:8040,EMP protocol:0301
    NEW SECURITY MODEL DETECTED
    PHONE IS RED RETAIL PRODUCT
    FLASH CID detected:53
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    OTP LOCKED:1 CID:51 PAF:1 IMEI:35379602288456 CERT:RED
    FLASH CID:53 COLOR:RED
    Model:W200i
    Brand:Orange
    MAPP CXC article: R4GB001 prgCXC1250725_ORANGE_ME
    MAPP CXC version: R4GB001
    Language Package:ORANGE_GEN
    CDA article: CDA102738/71
    CDA version: R9A
    Default article: cxc1250728
    Default version: R4GB001
    PROVIDER: 234-33
    Network LOCKED
    USERCODE:0000
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
    SECURITY UNITS BACKUP CREATED.
    Elapsed: 7 secs.
    SIGNED MODE (USING SERVER).
    ALTERNATIVE SECURITY BYPASS ENABLED.
    PRELOADER SECURITY BYPASS ENABLED.
    Speed:921600
    LDR:071219 1257 ESG_DB2012_FLASHLOADER_R2B017_CXC1326738
    Flash ID check:897E
    Flash props sent ok
    LDR:070904 1147 AN2CXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B014
    loader startup: executed
    loader GDFS startup: executed
    loader filesystem startup: executed
    loader unlock: executed
    DISCONNECT PHONE NOW
    INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
    BE SURE THAT YOU SET PHONE IN "PHONE MODE"
    IF ASKED, INSTALL PHONE DRIVERS
    SEARCHING FOR PHONE, "STOP" TO ABORT
    PHONE FOUND AT COM49
    PHONE READY TO PROCEED
    EXECUTOR STARTED
    REMOVE CABLE FROM PHONE
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    THEN PRESS "READY"
    Speed:921600
    Trying to launch embedded bootloader...
    INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
    Flash ID check:897E
    Flash props sent ok
    FOUND: R4GB001_CXC1250725_ORANGE_ME
    Restore from:R4GB001_CXC1250725_ORANGE_ME
    Searching...
    Firmware SIMLOCK check determined.
    LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V26
    writing tpa/preset/custom/C3_PCA_G3v2.cer
    writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    writing tpa/preset/custom/customize.xml
    writing tpa/preset/custom/DESKTOP_HOOK_2.itm
    writing tpa/preset/custom/Entrust.net Root Certificate.cer
    writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
    writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    writing tpa/preset/custom/GAMES_HOOK_3.itm
    writing tpa/preset/custom/GTE_CyberTrust_Root.cer
    writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    writing tpa/preset/custom/Root.cer
    writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
    writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    writing tpa/preset/custom/ThawtePremium.der
    writing tpa/preset/custom/ThawteServerCA.cer
    writing tpa/preset/custom/Utiroot.cer
    writing tpa/preset/custom/VeriSignClass3Root.cer
    writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Phone detached
    Elapsed: 185 secs.
    Old 07-08-2008, 14:18   #6 (permalink)
    Member: 786417
    Thank you, now it works !!!! i only flash with cruiser cid51 sw and raw fs, overwrite flash certivicate, thx!!!
    K850 5 locks closed after using EMMA Crazy_ratata Sony Ericsson 10 07-15-2008 17:54
    w200i 5 locks closed after unlock with SE Full unlocker handystoregsm Sony Ericsson 1 07-10-2008 10:09
    W200i 5 lock closed after unlock(cid52)in ub CHAPRAN Universalbox 6 08-11-2007 07:36
    5 locks closed after flashing k500i ASHIF Sonics Box 8 07-23-2005 11:09
    T68 4 Locks Closed After Reset Gdfs Help Please!!! XenKo78 Sony Ericsson 8 09-15-2002 12:43
    Page generated in 0.19991 seconds with 9 queries
