Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | W810 Cann't Make Connection With USB-Smart I Just Got W810i From Customer which Only Blinks for a Sec and Turn off Again. I have tried my best to make Connection between Usb smart and this Blinking Soul But No Luck. I ALways gets same Err. ERROR: Phone not power up have u any clu to make good Contact. Awaiting for handy Reviews. BR ![]() |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Man...your phone will be 100% work well, don't worry ![]() First, you have to connect power supply to cable about 4 volt and use battery ofcourse. make full flash include EEPROM. and do not work on hardware! Here is guide how to full repair W810 Usualy with this procedure can be solved ANY software problems (dead, Please Wait, ...) 1. - Use Test Point - NOT Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash MAIN file from MAIN directory (better latest version) - Not need to use Test Point on phone 2. - Use Test Point - NOT Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash FS file from FS directory (same version as MAIN file) - Not need to use Test Point on phone 3. - Use Test Point - NOT Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W810_EEPROM_Area_Flash.mbn as MAIN file - Not need to use Test Point on phone 4. - Use Test Point - NOT Checked - Skip TP when flash MAIN, FS - NOT Checked - On Repair tab mark Rebuild SP Area and Remake CRC's - Do Selected Jobs - Not need to use Test Point on phone 5. - Use Test Point - NOT Checked - Skip TP when flash MAIN, FS - NOT Checked - On Unlock tab mark Clear SP Locks - Do Selected Jobs - Not need to use Test Point on phone 6. - Use Test Point - NOT Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - Checked - Recover Certificate - NOT Checked - Remove all filenames from MAIN and FS edit boxes - Not need to use Test Point on phone |
![]() | #3 (permalink) |
Member: 128918 Status: Offline Thanks Meter: 282 | Brother I have tried all tricks Cable,Phone Connector 100% Okay here u can See. I can Connect it with HWK with same Cable ... But i can't Connect it with USB Smart ![]() ![]() I dunno whats Wrong with this Orphen Soft ![]() BR. |
![]() | #5 (permalink) |
Member: 128918 Status: Offline Thanks Meter: 282 | I Did All that Stuff When No Luck Comes after that i Make this thread. Well Brother I got HWK Cable which Don't need even .01 external Volts. Just give it a try Somtime ![]() Anyways U Can see HWK Cable Result without any External Volt. ![]() And I will Post Result after Flashing. Best Regards. |
K608i Cant Connect to USB-Smart or...... | thcoms | Sony Ericsson | 11 | 10-10-2006 20:35 |
need russian flash for w810 working with usb-smart | Siemens man | Sony Ericsson | 0 | 09-28-2006 16:52 |
J220 not connecting in USB-Smart | calinsuciu | SonyEricsson (USB-Smart) | 7 | 09-06-2006 16:47 |
w810 ERROR: 305401 with usb smart 8.2 mr zulea | .:T0PNET_GSM:. | SonyEricsson (USB-Smart) | 10 | 05-20-2006 05:59 |
Zulea you make the great usb-smart | mighel | SonyEricsson (USB-Smart) | 2 | 09-24-2005 14:19 |
