Motorola CDMA here all threads Related to Motorola CDMA Hardware Servicing and Repairing. |
02-20-2011, 14:36 | #1 (permalink) |
Registered User Join Date: Jul 2008 Location: (India) Age: 41
Member: 804452 Status: Offline Thanks Meter: 249 | motorola Q (tata base) only boot mode show .................................................. .............. any solution this modal pls post ya send this id [email protected] Hariom |
02-20-2011, 18:07 | #2 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: noida Age: 47
Member: 230569 Status: Offline Sonork: 1608865 Thanks Meter: 271 | Quote:
To perform a hard reset, hold down the center select key (s) for 5 seconds while turning the phone on. your problem solf hariom ok....... | |
The Following User Says Thank You to kumar_gsm_kumar For This Useful Post: |
03-03-2011, 10:44 | #5 (permalink) |
Member: 804452 Status: Offline Thanks Meter: 249 | This recipe will explain how to do a true master/hard reset and wipe all device data, restoring it to factory defaults/state. 1. Be sure to have atleast 75% battery on your Motorola Q 2. Be sure that you have backed up all data on the device since this will wipe the device clean 3. Power off the Motorola Q 4. Power on the Motorola Q 5. Once you see the initial carrier screen, hold the center button on the navigation pad. 6. Keep it held until you get a “Master Reset?” screen. 7. Click the left softkey for “Yes” and the phone will wipe and reload the OS from ROM BE SURE NOT TO REMOVE THE BATTERY WHEN YOU DO THIS or you may ‘brick’ your phone. Hariom |
The Following User Says Thank You to Hariom123 For This Useful Post: |
03-03-2011, 14:11 | #6 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
good information hariom sir.............. | |
03-04-2011, 09:59 | #7 (permalink) |
Freak Poster Join Date: Dec 2008 Location: kanpur
Member: 931438 Status: Offline Sonork: 1614828 Thanks Meter: 26 | nice job [QUOTE=Hariom123;7026078]This recipe will explain how to do a true master/hard reset and wipe all device data, restoring it to factory defaults/state. 1. Be sure to have atleast 75% battery on your Motorola Q 2. Be sure that you have backed up all data on the device since this will wipe the device clean 3. Power off the Motorola Q 4. Power on the Motorola Q 5. Once you see the initial carrier screen, hold the center button on the navigation pad. 6. Keep it held until you get a “Master Reset?” screen. 7. Click the left softkey for “Yes” and the phone will wipe and reload the OS from ROM BE SURE NOT TO REMOVE THE BATTERY WHEN YOU DO THIS or you may ‘brick’ your phone. thank u sir |
03-04-2011, 10:05 | #8 (permalink) |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
I have unlcoker for 51/61/32 for all new version for exchange Motorola 3*88 unlocker! | MC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-14-1999 13:02 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
