Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn > Karbonn Hardware Repair
Old 08-03-2014, 07:41   #1 (permalink)
Member: 1759693
Thanks Meter: 54
Needed Karbonn A1+ short solution.
Hello team members I need solution for A1
Namaskar all the team members and I need solution for karbonn A1+. Cause it is short. When i check with multmeter the (+) part of battery connector gives small beep sound not fully short. But when i check with trigger machine it gives short problem. Anyone in the forum pls help to solve the problem.
Old 08-03-2014, 13:34   #2 (permalink)
Member: 1860537
Sonork: 1657411
Thanks Meter: 39
remove cpister near bettery connector
Old 08-03-2014, 15:05   #3 (permalink)
Member: 1759693
Thanks Meter: 54
[QUOTE=viruscare;10472789]remove cpister near bettery connector[/QU
The capacitor near the battery connector already removed but still same problem.
Old 01-12-2015, 12:32   #4 (permalink)
Member: 2326894
[QUOTE=Syangwa;10472931]
Old 02-06-2015, 21:21   #5 (permalink)
Member: 1942086
Thanks Meter: 13
Bro its cpu problem......remove the cpu and check......a beep.....and resold cpu ur problem is solved........good luck
Old 02-27-2015, 15:21   #6 (permalink)
sb99sameerkhan's Avatar
Member: 1978625
Sonork: 100.1661449
Thanks Meter: 39
check rf ic & charging pin dear
Page generated in 0.20745 seconds with 8 queries
