Huawei Hardware Repair here you can get all the Hardware Repair information |
12-20-2022, 20:44 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: nador maroc
Member: 2093958 Status: Offline Thanks Meter: 82 | HUAWEI Y6 Y5 LITE 2018 Y5 LITE 2017 motherboard schematic diagram ways ic solution u Huawei Y6 (SCL-U31) Boards _ Huawei Y6 (SCL-U31) ICs_files FCC ID QISSCL-L01.pdf FCC ID QISSCL-L02.pdf FCC ID QISSCL-L03.pdf FCC ID QISSCL-L04.pdf FCC ID QISSCL-U23.pdf InternalPhotos-pdf-SCL-L01.pdf InternalPhotos-pdf-SCL-U23.pdf SCL-AL00,CL00,U31 Schematic Diagram.pdf SCL-AL00,CL00,U31(4A)Layout Diagram.pdf SCL-L03(4A)版位图.pdf SCL-L03线路图(4A).pdf SCL-TLXX Layout Diagram.pdf SCL-TLXX Schematic Diagram.pdf Y6 (SCC-U21)Service Manual.pdf Y6 SCL-U31 Board.pdf huawei scl-u31.jpg Y6 (SCL-U31) Charging&USB Ways.jpg Y6 (SCL-U31) Touchscreen Ways (2).jpg Y6 (SCL-U31) Touchscreen Ways.jpg Y6 SCC.SCL-L02 PCB Teardown B.jpg Y6 SCC.SCL-L02 PCB Terdown A.jpg Y6 SCC-U21 Charging&Mic Solution.jpg Y5 Lite 2018 Technical Announcement Guide.pdf Y5 Lite 2017 CRO-Lxx Advanced Maintenance Manual.pdf https://www.youtube.com/watch?v=7w-W...hannel=softrif |
