iPhone 5 iOS 6.0 FACTORY UNLOCKED HOW TO EDIT APN SETTINGS I have a factory unlocked Apple iPhone 5 on iOS6. I am trying to manually configure the APN settings so picture messaging and internet will work but there is no place to do it (on 5.1.1 it was settings/general/network). Any help appreciated. |
Just look for a wifi man . then goto to www. unlockit.co.nz make your own apn done happy browsing |
That works fine for web browsing but still need to enter the APN settings for MMS to work. Any suggestions. |
on my iphone ios6 it's settings->general->cellular->cellular data-> Br Faisal_Computer |
Same problem...i have iphone 4S iOS 6 unlocked...but when i use H20 but "Cellular Data" option disappear...i'm trying t-mobile sim card "cellular data" option appears.... any idea??...maybe i need install "tetherme" BR, Tech |
Connect wifi , then go to www. unlockit.co.nz , select make apn will apears the network , select network that you use , install , restart phone. |
Do it with itunes. iPhone, iPhone 3G, iPhone 3GS, iTunes 9 for Windows, iTunes 9 for Mac, iPad Wi-Fi + 3G Carrier settings updates are small files (about 10k) that are downloaded from iTunes to be installed on your iPhone or iPad Wi-Fi + 3G. The carrier settings can include updates to the default APN (how the device accesses the carrier's cellular data network). The carrier settings for iPhone also include special dialing codes at Settings > Phone > [Carrier] Services, default settings for Stocks, Maps, Weather, and other items. When you insert a new SIM or micro-SIM into an iPhone or iPad Wi-Fi + 3G, you must connect the device to a computer running iTunes to download the latest carrier settings. You should also install the latest carrier settings updates for your device as soon as they are available. To check if a carrier settings update is available for your iPhone or iPad Wi-Fi + 3G:
The carrier update files are stored in your computer in the following locations. see here |
Thanks buddy...internet connection again...works fine!!! BR, Tech |
