05-28-2018, 12:53 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | iphone 5s activation error no responce from apple server please try again help hi, i am facing this error after i restored manually from settings. but still facing same problem. tried over wifi and usb connection but both failed to activate it. usb connection method reply the iphone could not be activated because an unknown error occurred 0xe8000013, wifi connection reply Could Not Activate iPhone your iphone coult not be activated besause the activation server cannot be reached. Try connectining your iphone to iTunes to activate it. or try again in a few minutes. if this problem persists, contact Apple Support at apple.com/uk/support. pleae Apple team tell me how to solve this problem? thanks |
05-31-2018, 09:08 | #2 (permalink) |
Freak Poster Join Date: Jul 2013 Location: karimnagar
Member: 1986680 Status: Offline Sonork: 7210 Thanks Meter: 21 | iphone 5s activation error no responce from apple server please try again help Hello, sir are you able to see your imei and iccid at screen? Sent from my iPhone using Tapatalk |
06-17-2018, 14:24 | #6 (permalink) | |
Member: 1986680 Status: Offline Sonork: 7210 Thanks Meter: 21 | Quote:
Ok sir thanks for the response Sir just download 3u tools In that you will have an option called activate Just connect to the tool nd Activate hope this might help you Sent from my iPhone using Tapatalk | |
