Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 11-12-2017, 17:06   #1 (permalink)
Member: 2768974
Question iPhone 5S does not turn off
Hi,
I have an iPhone 5S with the above issue. I can turn it on but can't be turned off with the power on/off button, I checked the motherboard with a different iphone 5s housing but no luck.
someone please help.
Thank you
Old 11-12-2017, 17:08   #2 (permalink)
Member: 2683360
Thanks Meter: 6
Try to plug the battery
Sent from my iPhone using Tapatalk
Old 12-02-2017, 21:45   #3 (permalink)
Member: 2768974
the battery is already plugged in. I am able to switch it on but I couldn't switch it off.
Old 12-05-2017, 09:02   #4 (permalink)
it-repair's Avatar
Member: 1442842
Thanks Meter: 103
try to change the U25.. but carefully with the other parts in this area!!!!. Use not so much heat. If U6 or U9_RF is going off you will have a baseband problem!!!
The Following User Says Thank You to it-repair For This Useful Post:
Old 12-19-2017, 00:13   #5 (permalink)
Member: 2240742
Thanks Meter: 76
Look why make things complicated try new power flex if no luck then check the area neara j2 connector u have broken something near this power button connector but plz use microscope lool
The Following User Says Thank You to tarakhail For This Useful Post:
Page generated in 0.12463 seconds with 8 queries
