Need 1000000% solution for 4013 Hi frnds today i got Iphone 5s (GSM) with passcode lock i tried to restore all went well and restored successfully and after that mobile restarted for the configuration the mobile logo started blinking and i have an expert engineer here i told him not to remove the battery let the line finish but he didnt wait and removed the battery directly and mobile remained blinking now when ever i try to restore it gives me an error 4013 and stucks in recovery mode i tried new battery, changed the usb dock, removed the flex ,latest itunes,original usb cable, changed lcd ,all these i tried but still no luck ......................need solution................................... |
write mail to apple customer care.......... |
Change board that's 100% solution:)) |
1st of all delete the old firmware from computer and then go iphone to Dfu mode and then download new firmware 7.1.1 from your Iphine i hope your problem must be solved. Br. Mihut |
i've done that before to iphone 5s error 4013.. im just restore the unit without the full lcd with camera flex, and restore is complete... after that when i'll bring back the lcd with camera flex always appear apple logo only. but the restore is complete,thats why i remove the front camera and test... boom its working,without front camera. i'll replace the front camera flex with the new one... maybe the main problem of error 4013 is the front camera flex... |
dear bro, 1. if u near apple mac try in mac 2. if not remove all cable lcd,volume,headpohne, only coonect battery and usb cable u must charge battery upto 60% ok 3, if problem still remove steal clean board and put up the mercury simple bulb for 15 -15 minute 2 side 4. if problem still contact me pm this is not a big problem it is a voltage problem when u set update in itune!!! these thing distrub in upgrading |
How did you solve it???? |
yeah ...How did you solve it???? |
Mod sir, kindly close this thread the problem of that person solved. ======================== Never lose hope |
how did you solve the problem bro ? |
solution for error 4013 : I found solution for error 4013 iphone 5 to replace the display and touchscreen maybe this solution may help you all :);) |
Br. Mihut |
change board. thayt would be a definite solution |
