Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPad , iPod , Apple TV
iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV
Old 02-13-2021, 00:12   #1 (permalink)
Crazy Poster
Member: 2485239
Thanks Meter: 11
a1538 SN CHANGE NOT ACTIVATE
Hello all,
i bought a sn with wifi and bluetooth for the above mentioned ipad. It is using the a8 chip. I used irepair p10 to write the 3. Everything is ok until i have to activate. Then it fails to activate. I have tried 3 different combos and 3 other ipads. Yesterday i did a a1701 and no problems. Anyone can help? Am willing to pay to learn what im doing wrong.
Old 02-17-2021, 16:44   #2 (permalink)
Member: 2568440
Thanks Meter: 4
You are not just brother. On ios 14.4 A8 something else has been implemented that does not allow you to activate the device even by changing the 3 codes.
Old 02-21-2021, 20:13   #3 (permalink)
Member: 2277735
Thanks Meter: 215
I see this happening but need details like is it same device type and model? Or is it iPad 4 or mini one details you are writing?
Old 02-22-2021, 10:49   #4 (permalink)
Crazy Poster
Member: 2485239
Thanks Meter: 11
I am using another iPad data. The information matches because I use it on another A8 device and it activated with out a problem. It seems as though it’s only affecting the mini 4. Also if I write back the original data it will work because it asks for the iCloud. Text me on WhatsApp 17736562196
Old 02-22-2021, 10:49   #5 (permalink)
Crazy Poster
Member: 2485239
Thanks Meter: 11
Old 02-22-2021, 11:43   #6 (permalink)
Member: 1207296
Sonork: 100.1609587
Thanks Meter: 74
Originally Posted by ecuador91 View Post
Hello all,
restore original addresses
after jailbreak
bypass
Old 03-03-2021, 11:04   #7 (permalink)
Member: 2613325
Thanks Meter: 3
after jailbreak
bypass
Hi,
Could you please explain this a bit more? Can you jailbreak 14.4? How do you unlock the iCloud? Jailbreak and then change sn?
Old 03-07-2021, 22:57   #8 (permalink)
::. zine .::'s Avatar
Member: 161061
Thanks Meter: 568
because your ipad is cellular you need to remove transistor it will be activate after just see in youtube how to remove transistor
beware but your ipad will be wifi only he will not able to read sim
Old 03-12-2021, 15:59   #9 (permalink)
Member: 2613325
Thanks Meter: 3
That's not what we're talking about here at all mate.
The problem is that all of the devices with iOS 14.4 cannot be activated after SN change, regardless if it's WiFi or cellular.
BTW, anyone come across a solution for this yet?
Old 03-12-2021, 17:25   #10 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,126
iPad mini 4 won’t support no more , apple fix the hole for this model
Old 03-13-2021, 11:43   #11 (permalink)
Member: 2277735
Thanks Meter: 215
For a8... Anyone confirm for a10/a10x
Old 03-13-2021, 12:04   #12 (permalink)
ChelasGsm's Avatar
Member: 12966
Thanks Meter: 133
Tested all ipad except ipad 3 and 4 none activate i copy my own ipad mini 3 4 and ipad 10.5 clean serial write on them and still fail to activate
The Following User Says Thank You to ChelasGsm For This Useful Post:
Old 03-15-2021, 07:08   #13 (permalink)
Member: 2974086
i have the same issue with ipad mini 4,change serial,bluetoth and mac addres same cant activate!!anyone have sulotion for this?
Old 03-15-2021, 15:18   #14 (permalink)
Member: 2613325
Thanks Meter: 3
iPad Air 1/Mini 2 and older work fine, just the newer ones that are on iOS 14.4 don't work. So anything with A7 CPU is fine.
No solution yet for A8 and newer.
Old 03-29-2021, 13:29   #15 (permalink)
Member: 2613325
Thanks Meter: 3
Aaaaaaand A7 is now patched too. No more serial number changes unfortunately....
The Following 2 Users Say Thank You to sutek89 For This Useful Post:
Page generated in 0.26192 seconds with 8 queries
