GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   iPad , iPod , Apple TV (https://forum.gsmhosting.com/vbb/f851/)
-   -   a1538 SN CHANGE NOT ACTIVATE (https://forum.gsmhosting.com/vbb/f851/a1538-sn-change-not-activate-2947373/)
ecuador91 02-13-2021 00:12
Hello all,
i bought a sn with wifi and bluetooth for the above mentioned ipad. It is using the a8 chip. I used irepair p10 to write the 3. Everything is ok until i have to activate. Then it fails to activate. I have tried 3 different combos and 3 other ipads. Yesterday i did a a1701 and no problems. Anyone can help? Am willing to pay to learn what im doing wrong.
brek89 02-17-2021 16:44
You are not just brother. On ios 14.4 A8 something else has been implemented that does not allow you to activate the device even by changing the 3 codes.
P3T3 02-21-2021 20:13
I see this happening but need details like is it same device type and model? Or is it iPad 4 or mini one details you are writing?
ecuador91 02-22-2021 10:49
I am using another iPad data. The information matches because I use it on another A8 device and it activated with out a problem. It seems as though it’s only affecting the mini 4. Also if I write back the original data it will work because it asks for the iCloud. Text me on WhatsApp 17736562196
I am using another iPad data. The information matches because I use it on another A8 device and it activated with out a problem. It seems as though itís only affecting the mini 4. Also if I write back the original data it will work because it asks for the iCloud. Text me on WhatsApp 17736562196
akkose_iletisim 02-22-2021 11:43
Originally Posted by ecuador91 (Post 14332671)
Hello all,
restore original addresses
after jailbreak
bypass
sutek89 03-03-2021 11:04
after jailbreak
bypass
Hi,
Could you please explain this a bit more? Can you jailbreak 14.4? How do you unlock the iCloud? Jailbreak and then change sn?
::. zine .:: 03-07-2021 22:57
because your ipad is cellular you need to remove transistor it will be activate after just see in youtube how to remove transistor
beware but your ipad will be wifi only he will not able to read sim
sutek89 03-12-2021 15:59
That's not what we're talking about here at all mate.
The problem is that all of the devices with iOS 14.4 cannot be activated after SN change, regardless if it's WiFi or cellular.
BTW, anyone come across a solution for this yet?
Mr.3. 03-12-2021 17:25
iPad mini 4 won’t support no more , apple fix the hole for this model
P3T3 03-13-2021 11:43
Originally Posted by Mr.3. (Post 14353936)
iPad mini 4 wonít support no more , apple fix the hole for this model
For a8... Anyone confirm for a10/a10x
ChelasGsm 03-13-2021 12:04
Tested all ipad except ipad 3 and 4 none activate i copy my own ipad mini 3 4 and ipad 10.5 clean serial write on them and still fail to activate
victory_08 03-15-2021 07:08
i have the same issue with ipad mini 4,change serial,bluetoth and mac addres same cant activate!!anyone have sulotion for this?
sutek89 03-15-2021 15:18
iPad Air 1/Mini 2 and older work fine, just the newer ones that are on iOS 14.4 don't work. So anything with A7 CPU is fine.
No solution yet for A8 and newer.
sutek89 03-29-2021 13:29
Aaaaaaand A7 is now patched too. No more serial number changes unfortunately....
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.13943 seconds with 6 queries
