GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   iPad , iPod , Apple TV (https://forum.gsmhosting.com/vbb/f851/)
-   -   a1538 SN CHANGE NOT ACTIVATE (https://forum.gsmhosting.com/vbb/f851/a1538-sn-change-not-activate-2947373/)
akkose_iletisim 06-15-2021 21:59
Hello All Friends
apple Now updates security patches
but it won't happen later
maybe there will be a solution soon
(But for now the best method
jailbreak and bypass method)
restore original address
then jailbreak and bypass
attached file is available
a thank you please.
And thanks Waseem Tech..
https://mega.nz/file/IhYDwK4D#fVFG37...TAAZf9K1UwchMI
SAEIDSANGAN 06-19-2021 19:56
If your ipad is gsm first change to wifi remove board id resistor
Device go to dfu mode
Write wifi model sn bt mac
Restore with wifi version
Done
P3T3 06-24-2021 19:44
If you remove resistor now you HAVE to change WiFi chip on air 2 up, the swap drivers dos not work anymore.
Best way is just to bypass iPads, can get all functions without messing about, Apple will start to block SN change as they have on mini 4s.
akkose_iletisim 06-26-2021 17:54
All ipad icloud remove change sn purple mode
ipad pro 1 9.7
ipad A1822/a1823 change wifi ic
ipad air A1567/a1566 change wifi ic
have All iapd sn number clean
activaiton all ok
www.kilityok.com
https://i.hizliresim.com/xjxy6h3.png
P3T3 06-30-2021 10:31
ipad pro 1 9.7
activaiton all ok
Sorry A8 are blocked, yes can rite to all iPad but they won’t activate, even with clean details!
Mr.3. 06-30-2021 10:47
what about A7 cpu atm,
akkose_iletisim 06-30-2021 16:56
please cli,ck www.kilityok.com
change sn number
A8
for model: ipad air2/ipad mini4/ ipad mini 4 gsm change wifi ic/ipad 5 A1822/A1823 change wifi ic/ipad pro A1673/A1674 change wifi ic
ipad pro 10.5/ann gsm change wifi ic/ipad 12.9 1 generation and gsm chang wifi ic/ ipad pro 12.9 2 generation and gsm change wifi ic
all test ok ok ok ok ok
https://www.resimupload.org/images/2...nshot_6_LI.jpg
emrez 07-02-2021 21:33
Clean New serial work. Thank you. ��
emrez 07-02-2021 21:34
Clean New serial work. Thank you. 🙏
Mr.3. 07-03-2021 02:49
For a7 whats the solution … need to change WiFi ic too ?
emrez 07-03-2021 14:52
A7 mini 2 4g add fuse, air 2 4g remove fuse and serial replace work. A7 not request wifi ic.
Mr.3. 07-03-2021 15:11
Do u have any pic of fuse ? Thanks
P3T3 07-04-2021 09:00
https://pasha4ur.org.ua/articles/dif...cloud-locked/8
P3T3 07-04-2021 09:29
Originally Posted by P3T3 (Post 14420385)
But it will probably give activation error, you would have to rite new details.
Just use an iCloud bypass, will be allot quicker.
Mr.3. 07-04-2021 12:41
I mean even iPad WiFi only device can’t activate with new serial , is that bug fixed
Ex : iPad Air WiFi only
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.13122 seconds with 6 queries
