GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   iPad , iPod , Apple TV (https://forum.gsmhosting.com/vbb/f851/)
-   -   a1538 SN CHANGE NOT ACTIVATE (https://forum.gsmhosting.com/vbb/f851/a1538-sn-change-not-activate-2947373/)
chand_gee 11-20-2021 17:40
hi to all
i was out of work now back again.....
dont no what is work or what is not work butt
yesterday here in dubai i able to change
sn bt wifi mac on a1566 ipad air 2 with a8 cpu
and its activated
P3T3 11-20-2021 23:39
Originally Posted by chand_gee (Post 14481499)
hi to all
and its activated
Air 2 not issue, air 1 and mini 4 you won’t be able to activate.
Mr.3. 11-22-2021 06:04
hi to all
and its activated
5.1 worked ? .
Sitlay KING 11-25-2021 12:17
hi to all
and its activated
Sir You know everything and here you are acting like a kid :P
only mini4 and ipad 5 was not able to activate but there is solution about that also.
Contact me the way i contact you.
Mr.3. 11-25-2021 12:58
i have ipad mini 4 can you help me to bypass ?
P3T3 12-03-2021 00:30
There’s lots of free untethered bypasses.
Mr.3. 12-03-2021 06:10
bypass was done i want to do permanently
killme12 12-03-2021 14:36
I have Ipad A1823 with Sim i want to unlock it by hardware
it needs to change wifi ic also after modifying
so the problem is which wifi ic i have to put in
can some one plz guide me
emrez 12-04-2021 21:11
Hi,
No iOS activation for ipad mini 4 and ipad 5. İos 12-14 Mina by-pass work.
P3T3 12-05-2021 01:34
I can do iPad untethered to iOS 14.8.x, Mina to expensive.
nikhil_gsm 12-05-2021 07:40
Hi , I have Ipad A1822 ipad 5th gen ios 15.1 is there any solution ?
Gsm::Boiragi:: 05-09-2022 14:45
it was true i facing same problem with AIR 1 tried 2 deferent mac still same not active
solution please
shahsoft 05-15-2022 05:43
i have ipad mini 3 A1599. It's A7 chip and iOS 12.5.5. First I tried many serials but then I ordered A7 serial,BT and WifiMac. The serial and other info came from server. Successfully edited the sysconfig with received info from server. But now still it's not activating. Also restore the firmware and then still.
then I tried the original info with the fmi ON so it was still not activating and I then restore and then it's activated but still the same FMI On icloud obviously.
I also paid for the serial which is not a big deal but if anyone have a solution especially for MINI 3 A1599 A7. then please let me know. thanks
avsen 05-19-2022 01:47
Hello everyone. I made the mistake of modifying sn and bt but I didn't make a backup. do you have a solution to recover bt and wifi info via sn? thank you in advance.
It’s for ipad mini 4 chipset a8
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.14328 seconds with 6 queries
