iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV |
04-21-2019, 16:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | ipad mini udid fffff in 3utools error 9 in iTunes after remove the nand try to restore in 3utools but I see in logs that it has blank udid was icloud problem logs in 3utools 07:45:42 Signing firmware 07:45:42 Apple mobile device will connect to DFU mode automatically 07:45:44 Retrieving information from mobile device 07:45:44 Writing AppleLogo 07:45:44 Writing RamDisk 07:45:46 Writing DeviceTree 07:45:46 Writing KernelCache 07:45:47 Apple mobile device will connect to normal mode automatically 07:46:00 Device UDID: [ffffffffffffffffffffffffffffffffffffffff] 07:46:00 Initializing port 07:46:05 Transferring restore configuration file to apple mobile device 07:46:05 Receiving data from apple mobile device 07:46:05 Processing RootTicket 07:46:05 Writing RootTicket 07:46:05 Receiving data from apple mobile device |
05-01-2019, 08:28 | #3 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: karimnagar
Member: 1986680 Status: Offline Sonork: 7210 Thanks Meter: 21 | Quote:
i was also faceing the some problem check if there are any shorted capacitors near nand and check the voltage to the nand press thanks if it works | |
The Following User Says Thank You to kunal124 For This Useful Post: |
