replaced my ipad screen, but now not taking touch input Hello, I hope that someone can provide some insight. I just went through my first time replacing a cracked digitizer on my ipad mini. As I was finishing up and before I allowed the new digitizer to seal into place, I powered up the ipad to make sure all was working. Everything seemed to be in order, the LCD was beautiful and the screen was taking my touch inputs without a problem. I powered down, exposed the adhesives on the digitizer and fastened into place. Now the system wont recognize my touch. I have tried to reposition the digitizer multiple times with no change. The LCD still looks great but it wont recognize input. I do not understand at all as it was working perfectly right before I sealed the screen. Any help would be appreciated. |
try first Hard reset - Home and Power button at the same time for 7-10 sec or to the time you see Apple logo. |
Hard reset, if not check digitizer cable is folded correct and connected to logic board correct! |
ipad2 air mini no touch I need help on a ipad2 mini model A1489 touch wont work after two new screen replacements, can you plis tell me the ic that controls the touch. |
remove the battery. try again is it installed properly? |
thanks alot for this |
Unfortunately apple is such a technology that fixing anything affects the operability of the device later on. I also replaced the screen on my iPad mini, after which I could have just thrown it away. |
