iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV |
11-05-2018, 05:29 | #1 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | [Solved] How to Replace iPad Air 2 Broken Glass? Step 1: Firstly, you need an iPad Air 2 screen with broken glass lens but properly working touch digitizer and LCD display. Install LCD to motherboard plate, then test if the display, touch functionality is OK. Step 2: In the first place, we need to stick a layer of adhesive tape on the full surface of the LCD screen. Get it heated on 13” LCD Separating Machine. Press the vacuum button, then embed the gold cutting wire into the bottom of LCD screen, pull it right and left till the glass separated. Step 3: Dip some 8333 OCA Cleaner with Anti-static Glass Wiper, spread it on LCD for 1 minute. And remove the residue adhesive. Step 4: Respectively tear off the protective films on new glass lens and OCA, align them then laminate. After that, place glass lens into Glass Laminating Machine for bubble removing for 3 minutes to make sure air bubbles between OCA and glass lens completely removed. Step 5: Put the LCD into Alignment LCD Mold and clean it. Tear off another protective film on OCA glue. Then align glass lens with LCD and put it into a mold for preliminary lamination. Take out the LCD and put it into Glass Laminating Machine with a laminate cushion placed under it. You should be more careful of the placement of LCD flex cables at this moment. Place another clean glass lens onto the LCD Assembly and align them to make complete lamination. Take it out after glass laminating is done. Step 6: Connect the LCD to the motherboard, and then test the display and touch functionality again, both are OK. The related video for your better understanding click here. |
