Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPad , iPod , Apple TV
iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV
Old 10-20-2020, 16:33   #1 (permalink)
Member: 2638773
Thanks Meter: 3
unlocked ipad mini 4 with serial, locked again !!!
Hello friends
two years ago i bought a serial number to unlock an ipad 4mini with nand flash programming.
today i logged out of my apple account, i reset the device and activating it is blocked with a new apple account. How is it possible? someone has occupied the serial in 5 minutes?
Old 10-20-2020, 17:26   #2 (permalink)
Member: 169896
Thanks Meter: 323
Originally Posted by Ragusego View Post
Hello friends
It was actually activated on another device already. Once u restored then on Apple server the other one got active. Change it again with new one
Sent from my SM-G986W using Tapatalk
Old 10-20-2020, 19:42   #3 (permalink)
Member: 2638773
Thanks Meter: 3
so the same serial is used on multiple devices? how can you safely reset it without locking? thank you
Old 10-21-2020, 01:27   #4 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
Login with icloud is actually cant enable fmi on......
What i do for on it
Change sn
Restore and activate
Reset erase all
In startup add passcode and apple id
Connect with itune sync
Reboot ipad sync again
Then check status will be on
Now you have occupied sn
The Following User Says Thank You to chand_gee For This Useful Post:
Old 10-25-2020, 11:19   #5 (permalink)
Member: 2638773
Thanks Meter: 3
Hello Friend,
how can i give my ipad to someone without my icloud account?
thanks
Old 10-25-2020, 15:33   #6 (permalink)
ChelasGsm's Avatar
Member: 12966
Thanks Meter: 133
Hello friends
I made same mistake on 20 serial after change always activate icloud, go to icloud panel make lost and erase serial will be linked to your icloud, only remove when customer came and activate icloud again
Old 10-26-2020, 22:55   #7 (permalink)
Member: 2277735
Thanks Meter: 215
Always check each seiral from seller on ic check!
Allot will actually say refurbished from legit resellers, I use https://www.vipprogrammer.com/unlock...rogrammer-5234
Only mini 1 and iPad 2/3/4 sireals but I have flashed them to pros and mini 4 with no issues, updates to iOS 14 and not relocking.
Old 12-26-2020, 16:08   #8 (permalink)
Member: 2975003
Sonork: Donnajill77
any working solution, I am also facing same issue
Page generated in 0.17517 seconds with 9 queries
