12-18-2008, 12:36 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Daet Cam., Norte Philippines
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | iPhone A1203 advice! here is the pic. action taken: tried manual reset. no luck, I tried to use iTunes 8.0, and 8.2 but when I tried to load the ipsw got an error 1403. I also used 1.1.4 version of ipsw. but in the end got a 1601 error! even if I tried other PC. I also have other ipsw versions like iPhone1,1_2.0.1_5B108_Restore.ipsw, iPhone1,1_2.2_5G77_Restore.ipsw, and iPhone1,1_1.1.2_3B48b_Restore.ipsw. But it does'nt work. Need help and advice on this thanks! |
12-19-2008, 05:37 | #2 (permalink) |
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | I am now using iTunes 7.5 and v1.1.4ipsw and the phone is now on restoration process. How many hours does it take to restore an iPhone? because it is almost 1 and half hours now and not yet finished. Does the process have a problem do I have to restart the process or wait and continue? need advice thanks! |
12-19-2008, 11:57 | #3 (permalink) |
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | After using iTunes 7.5 with 1.1.4ipsw. Restore process is done with error 1105 but I use ziphone 3.0 press do it all! the menu appears but always no network even I can call on emergency 112. So i tried again ziphone and press downgrade boot loader. But still no luck always no network support here in the Philippines. Is there any other way to make this phone work back to it's normal signal? According to the owner it works fine with signal. But now I can only make 112 emergency call. hope somebody help me thanks! |
12-19-2008, 14:05 | #4 (permalink) | |
Crazy Poster Join Date: Apr 2007 Location: tunisia
Member: 495862 Status: Offline Thanks Meter: 10 | Quote:
enjoy yes2005 | |
12-19-2008, 14:09 | #5 (permalink) | |
for the signal or network after restore, jealbreack and unlock you should be use the ZiPhone patched by kIREmK 04.05.04_G to downgrade the baseband of your iphone yes2005 | |
The Following User Says Thank You to yes2005 For This Useful Post: |
12-19-2008, 14:30 | #6 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
no need downgrade. just follow this instruction.your phone will be 100% ok. http://www.iclarified.com/entry/index.php?enid=1880 next time use search button.many time post this type thread | |
The Following User Says Thank You to shahinahmed007 For This Useful Post: |
Apple iPhone A1203 UNLOCKING | tajinder | iPhone 2 / iPhone 3G / iPhone 3GS | 28 | 11-12-2010 09:17 |
help me iphone model no A1203 8GB | jahednn | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 05-08-2009 12:25 |
Big Pb With Iphone A1203 BOTTON SOME NUMBER NOT WORK | SHIJILFONOTLY | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 08-03-2008 10:35 |
Big Pb With Iphone A1203 | .::AssAnovic.:: | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 02-04-2008 01:25 |
