03-16-2014, 23:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: india
Member: 879851 Status: Offline Thanks Meter: 16 | iPhone 3G not able to restore Hi frnds, Every time i try to restore iPhone 3G its not able to restore completely and gives same message every time"iPhone could not be restored,An unknown error occurred (1015). please suggest solution for that. |
The Following User Says Thank You to jazzbrar For This Useful Post: |
03-17-2014, 16:08 | #2 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1640023 Status: Offline Thanks Meter: 1 | this iphone have jailbreak, you need restore one custom ios, find in the web custom ios for your iphone, you could make ur custom ios with snowbreeze, for restore you need some old version itunes. |
The Following User Says Thank You to fullwave66 For This Useful Post: |
03-18-2014, 08:00 | #3 (permalink) |
Member: 879851 Status: Offline Thanks Meter: 16 | I did that as you said but nothing change same error coming when firmware updating giving same error at the end.Please help.thanks |
03-18-2014, 10:16 | #7 (permalink) |
Member: 879851 Status: Offline Thanks Meter: 16 | I already done the above procedure but same problem its stuck at firmware updation and same error comes then.My phone is 3G A1241 thnx Sent from my GT-I9300 using Tapatalk Last edited by jazzbrar; 03-18-2014 at 10:24. |
03-18-2014, 10:22 | #8 (permalink) |
Member: 879851 Status: Offline Thanks Meter: 16 | I think that was version 4.1.8 Which I m using as custom.is this creating problems with this phone can I use it again with the correct version of software.thnx Sent from my GT-I9300 using Tapatalk |
03-18-2014, 21:24 | #11 (permalink) |
Member: 879851 Status: Offline Thanks Meter: 16 | Thanks for support, it worked but now no Sim card message coming even with SIM card installed and no WiFi working .what to do now.thanks Sent from my GT-I9300 using Tapatalk |
03-21-2014, 22:05 | #15 (permalink) |
Member: 879851 Status: Offline Thanks Meter: 16 | USB communication problem when trying to enter in pwned DFU mode to prepare for restoring custom IPSW using redsnow.please suggest. Thnx Sent from my GT-I9300 using Tapatalk |
