what is ur device serial number? WBR |
PEOPLE!!!!!! NOW IF YOU HAVE NEW IPHONE 3GS (WITH NEW BOOTROM) WHEN YOU USE Blackra1n FOR THE UNLOCK YOU ALWAYS HAVE GOT RECOVERY MODE AFTER REBOOT !!!! FOR NOW NO SOLUTION!!!!! (you can use Blackra1n once again, your iphone will be activated, but when you reboot it, it will be blocked again) |
i also face this problem in 2pc iphone how solve or wait for new update? b.r |
my serials 4th and 5th numbers is "44" can i unlock it without any problms?? |
still waiting for a solution on the new boot. i think now its concerning many people i was one of the first to in counter the problem. And the holidays are coming that means many new iboot iphone will be in the market. |
i have the same problem with my iphone plz tell me the anser about recovery mode? |
AND ME i have a same probleme now plz i need this restore restore unlocked for 2g 8 G QODS GSM TAZA |
just connect iphone 3gs to computer and run blacksn0w and all ok until u turn off phone or reboot, then do it again and again until new hack is available, ... wait days or months ... |
You do have to do connect to the computer to reboot your phone if you ever need to or if your battery runs down. If you consider that a problem then that is a different story but serial 44 isn't a problem to unlock or jailbreak. I just did it. Follow the tutorial, Make sure you are actually connected to a wifi network (mine said it was connected and it wasn't) and then download and install Cydia, Rock, & Snow and you should have no issues at all. Make sure you change your /root password once you get into your phone |
i have the same story.any help me be highly appciated. |
same issue with 3gs after run blackrain i was trying to restore with custom firmware but stuck in dfu mode any solution?please help.... |
For me Having 3G's ....Same Problem With Me... As I tried All Way... Everything Is going ok..bot not working...still the same problem Here Is Log C:\I>irecovery -s iRecovery - Recovery Utility by wEsTbAeR-- and Tom3q Got USB ======================================= :: :: iBoot for n88ap, Copyright 2009, Apple Inc. :: :: BUILD_TAG: iBoot-636.66 :: :: BUILD_STYLE: RELEASE :: :: USB_SERIAL_NUMBER: CPID:8920 CPRV:15 CPFM:03 SCEP:03 BDID:00 ECID:00000 343A12038D IBFL:01 SRNM:[87942G443NQ] :: ======================================= [FTL:MSG] Apple NAND Driver (AND) RO [NAND] Found Chip ID 0x3E94D72C84 on FMI0:CE0 [NAND] Found Chip ID 0x3E94D72C84 on FMI0:CE1 [NAND] Found Chip ID 0x3E94D72C84 on FMI1:C8 [NAND] Found Chip ID 0x3E94D72C84 on FMI1:CE9 [FTL:MSG] FIL_Init [OK] [FTL:MSG] BUF_Init [OK] [FTL:MSG] FPart Init [OK] read new style signature 0x43313133 (line:375) [FTL:MSG] VSVFL Register [OK] [FTL:MSG] VFL Init [OK] [FTL:MSG] VFL_Open [OK] [FTL:MSG] YAFTL Register [OK] yaFTL::YAFTL_Open(l:2630): CXT is not valid . Performing full NAND R/O restore .. [FTL:MSG] FTL_Open [OK] Boot Failure Count: 2 Panic Fail Cout: 0 Delaying boot for 0 seconds. Hit enter to break into the command prompt... HFSInitPartition: 0x4fafeb40 Kernelcache image not valid Entering recovery mode, starting command prompt (Recovery) iPhone$ setenv auto-boot true (Recovery) iPhone$ saveenv (Recovery) iPhone$ /exit Closing USB connection... |
Tell me what dou have when you type 'help' My Iphone don't answer eny command :/ Only workt "reboot" - iphone is restarting I don't know what is wrong with connection with PC <-> Iphone |
when will geoHot release new jailbreak any idea ??? |
