06-09-2008, 00:37 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 203576 Status: Offline Thanks Meter: 11 | EDGE settings not being saved ***help*** Now, I have installed FRING... same problem... works perfect over Wifi but does not seem to connect over EDGE/GPRS. are there any system files that I can tweak around with to see if EDGE settings are being saved properly for all apps. Or does every app has its own specific file storing EDGE settings. Help much appreciated ! Jazz |
06-09-2008, 01:14 | #2 (permalink) |
Member: 203576 Status: Offline Thanks Meter: 11 | I SSHed into my fone and tried some debugging, executed the app binary didnt make any sense to me... but it may help in resolving my issue. Thanks. 2008-06-09 01:06:05.054 Fring[1064:d03] Couldn't register with bootstrap server unknown error code (0x44f); failing... 1064: ABORT: Unable to register "com.fringland.fring" port, 1103 unknown error code zsh: abort ./Fring |
06-09-2008, 01:24 | #3 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Australia
Member: 390241 Status: Offline Thanks Meter: 18 | Hi There Freind: if this helps to fix most bugs on iphone there is a haed reset you obviously know (hold home+power button for 15 seconds) and that might help you or there is an application called (BOSSPREFS) i am pretty sure that it enables you to activate or deactivate settings over apps good luck bro all the best |
06-09-2008, 16:33 | #4 (permalink) |
Member: 203576 Status: Offline Thanks Meter: 11 | @ yalcinHacker not even close mate... im talking about something a bit more complicated then just installing BossPrefs and toggeling some buttons... Thanks the attempt though... |
06-09-2008, 19:21 | #5 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: You Can Never Go There
Member: 55841 Status: Offline Thanks Meter: 16 | Quote:
about fring over edge i dont think u will get a good sound quality. BR | |
K205i picture cannot be saved solved | keaelite | Infinity-Box | 2 | 04-14-2009 08:53 |
iPhone 3G EDGE Setting | yueyo | YESSIM | 1 | 08-30-2008 15:31 |
Edge Settings Not Saving | andy1505 | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 04-12-2008 10:56 |
w200 camera picture could not be saved! | aikonmani | Sony Ericsson Hardware Repair | 1 | 01-03-2008 04:49 |
